Timing/Distributor Issue
Another issue, the two screw holes on the distributor, where the ICM connects to, is stripped out. The ICM doesn't seem to be firmly attached. Should I just get a new distributor? Is there anything else I can do?
Oh yeah, it's a 86 F-150 302 V8 FI
Unplugging the SPOUT (SerialPulseOUTput) sets it back to base fixed timing, taking the computer out of the equation so the timing can be set manually.
The bad news - The stripped-out screw holes are a big problem. That module sinks its heat to the body of the distributor, that's also why heat transfer grease is used between the module and the body. The distributor body becomes the heatsink for the module. Without a good tight thermal connection between the two, the module will overheat and fail.
I don't remember if there is enough clearance/space inside the distributor to use longer screws, and then put nuts and split-ring lockwashers inside?
Otherwise, I think it means a new distributor.
<O
</O
Go to a computer repair shop and buy a used CPU heat sink and some thermal heat sink compound. Apply heat sink compound between the two and clamp them together for the drive home
http://en.wikipedia.org/wiki/Thermal_grease
<O
</O
You can just use a clamp to get home then drill and bolt them together when you get the time later on. Place the heat sink away from engine heat and in the airflow to cool.
<O
</O
Don’t attempt the 8 hr drive without a good heat sink on the IGN module.
Good Luck
Jim
Due to the heat issue with mounting the IGN module on the distributor Ford moved the IGN module. On later trucks it is mounted to a heat sink on the left inner fender near the hood hinge attach point. This heat sink is drilled and tapped with the same mounting holes to mount the IGN module. If you can find one of these heat sinks at a junk yard it would be an easy long term fix.
In the photo below I used one of these heat sink to mount a GM 4 pin module. In the end I ending up using a computer heat sink as it had better fins to draw the heat away from the IGN module.
[/SIZE
I put a new distibutor in and set the timing (had to buy a timing light). It seems to be running as good as it was before my Ignitioin Control Module went out.
Since I had to reuse the ICM that I bought yesterday on the new (rebuilt) distributor. I didn't have any of that white paste that you rub on it before attaching it. The parts place said I should use some diaeletric grease, the stuff you put in spark plug boots, on the ICM. Is this cool or am I screwed because I already put it on there?
Also the reason I think the ICM went out is because of the high heat here in Austin, TX plus my truck is overheating at idle or in slow traffic. See my new thread: Fan Clutch - Ford Truck Enthusiasts Forums
Thanks again. And to JimsRebel, I will definately consider putting on a heat sink later. You advice came when I was working on my truck and I just got back inside.
I moved my IGN module into the air flow and off the hot engine. Plus I have a "ride along spare".
hope you made it home safely!
Nice heatsink Jim! I might have to rig up something similar, but a bit more elaborate, for the custom ignition system in one of my RX7's. It uses 3 of those GM 4 pins and 3 seperate coils. Shortly after I got the car, all 3 modules failed, due to having been packed with dielectric grease, and bolted to 22g sheet metal.......
Currently, I'm using 3/16" stainless plate + artic silver 5, and have them out in the airflow. They still get a bit warmer than I like.......
