Power Steering Issue-need help
Old Aug 27, 2010 | 04:05 PM
Jayybird's Avatar
Jayybird
Fellas,
I need a little direction on this.
I have a 2005 Ford F250 6.0 powerstroke short will base, FX4 with 130k miles.
I just started noticing that I have a stiff spot in my steering. When turning to the left (counterclock) it feels normal and resistance free. When turning to the right (clockwise) at about 3 o clock I feel resistance. What could this be? Am i having powersteeing pump issues? I check the fluid and with the engine cold the fluid is barely touching the dipstick. My plan of action is to change out the fluid with some fresh.
What esle can I check to help trouble shoot the problem. I have a tuner and am not picking up any codes.
Thanks
Any input is appreciated.
Old Aug 27, 2010 | 06:36 PM
steelhead2's Avatar
steelhead2
check the steer shaft real good. sounds like you might have a bad u-joint.
Old Aug 27, 2010 | 06:42 PM
cheezit's Avatar
cheezit
check the stabelizer shock for damage
Old Aug 27, 2010 | 06:43 PM
69cj's Avatar
69cj
Personally if I were you I would have flushed the p.s. system a long time ago but then again I'm **** on that type of stuff. I flushed with 4 qts. of syn. mercon V and installed an a.t. in line filter. At 40,000 miles the fluid looks and smells better than the fluid from the factory. You could also have a bad spot in the steering gear box. That would be my guess. And I did say guess.
Old Aug 27, 2010 | 07:04 PM
phoenixrhino2's Avatar
phoenixrhino2
Power Steering Flush
Hello All,
Well I finally got around to doing a Power Steering Flush and thought that I would post-up some pics of the Old vs. New Fluid for anyone considering doing some simple maintenance.
I was not having any trouble with the PS, but figured it was time for a change now over 50k.
I used the procedure found at the below link, and worked great!
Ford Super Duty Power Steering Flush | Superdutypsd.com
Pic posted on Powerstroke Forum. Sorry can't load pics here!
Power Steering Flush Pics - Ford Powerstroke Diesel Forum
Old Aug 27, 2010 | 08:55 PM
rocky1074's Avatar
rocky1074
Thanks for the information phoenixrhino2 I was planning on doing it now I know how. I already have the Magnefine filter installed, did it about a year ago. Thanks Again...Rocky
The filter is 15.44 on this site.. http://www.bulkpart.com/Merchant2/me...=inline-filter
Old Aug 27, 2010 | 10:16 PM
Jayybird's Avatar
Jayybird
Fellas,
Thanks for the suggestions, I'll be looking into this. Do we have directions on how to do the PS flush on the 6.0. I just looked at Phoenix's link, thats for the 7.3...i assume its the same as our 6's?
Old Aug 28, 2010 | 10:01 AM
phoenixrhino2
The PS pump is in the same location, so using the instructions (link) in post # 5 will work. When I was reviewing some threads before I did mine, several people have had good luck with the flush fixing some of their PS problems.
Good Luck.
