Same as 4.9?
Old Aug 27, 2010 | 01:32 AM
F-250 restorer's Avatar
F-250 restorer
Same as 4.9?
Does anyone know if the flywheel and clutch that came with the 4.9 with a ZF are the same as those on a 351W with the same oem trans?
Old Aug 27, 2010 | 07:11 AM
BaronVonAutomatc's Avatar
BaronVonAutomatc
The flywheel has a different balance, but the clutch and pressure plate are interchangeable.
Old Aug 27, 2010 | 10:47 AM
F-250 restorer
Another question: Since I have a flywheel from a '75, is that the same as the one I would get from the ZF years on a 4.9?
Old Aug 27, 2010 | 06:53 PM
BaronVonAutomatc
Should be the same, I don't think there were variations in bell housing/flywheels for the I6 after ~1972 - at least not teeth or diameter wise. Worst case take it to NAPA and compare it to a newer one.
Old Aug 27, 2010 | 07:35 PM
F-250 restorer
Of course! Why didn't I think of that?
Old Aug 27, 2010 | 10:18 PM
Harte3's Avatar
Harte3
You are still obsessing about a cold drink of water...
Old Aug 27, 2010 | 10:56 PM
johnboy427's Avatar
johnboy427
M5 flywheels work with the ZF too, they are a lot easier to find.
-John
Old Aug 28, 2010 | 12:05 AM
F-250 restorer
-John
What is an M5 flywheel?
Old Aug 28, 2010 | 01:16 AM
johnboy427's Avatar
johnboy427
The M5OD used in the half tons. It was the light duty 5spd, and there are a lot more half tons with 300s than 3/4 and 1 tons.
-John
Old Aug 31, 2010 | 11:06 PM
200000+F150's Avatar
200000+F150
-John
Yep, so far all the flywheels, clutches and pressure plate on the later ones are the same. The only differences in any of them that I've seen are the throwout bearings (std fork on older, hydraulic on later).
F-250 restorer
Aug 27, 2010 12:04 PM
jasongt06
May 25, 2009 10:37 PM
Katmandu2
Aug 26, 2003 03:21 AM
redn8
Feb 3, 2002 04:21 PM
