Throttle Body bore sizes ??
Aug 12, 2003 | 09:51 PM
What's the diameter of the 4.9L's Thottle Body bores ??
Aug 12, 2003 | 10:07 PM
It's either 43 or 44mm I forget which and it's too much hassle to go measure
Aug 13, 2003 | 03:02 PM
OK... How much larger are the 460 Thottle Body Bores ???
Aug 13, 2003 | 04:03 PM
Don't have a clue. 5.0 T/Bs are 50mm
Aug 13, 2003 | 04:23 PM
The bore size isn't mentioned, but there is a post somewhere that talks about a 4.9 to 460 T/B swap. It sounds like you're headed in this direction.
Aug 13, 2003 | 05:17 PM
Quote:
5.0s are Single bore Throttle bodies whereas our 4.9L are dual.
Quote:
Yea, that's what got me thinking about this..... Just curious as to what the size difference between the two are.
Aug 13, 2003 | 05:32 PM
Quote:
Not in the trucks.
Aug 13, 2003 | 07:56 PM
Quote:
Originally posted by Silver Streak
Not in the trucks.
Goes to show how many trucks hoods I've looked under huh ?
Aug 23, 2003 | 08:50 PM
351w's use 50mm dual throttle bodies
Aug 23, 2003 | 09:07 PM
Quote:
Cool!
So, 300s are 43mm, 5.0s are 50mm, 351s are also 50mm. So what are 460s ??
Aug 26, 2003 | 03:21 AM
Cool!
Just found this pic of the 460 Throttle Bodies... BTW, they are 61mm in Diameter!
dirtbikehigh
1997 - 2003 F150
Oct 21, 2015 07:33 PM
Stockbuilder
1983 - 2012 Ranger & B-Series
Oct 4, 2014 09:33 PM
2speed
Oct 10, 2006 02:45 PM
MisterCMK
The Next Generation
Apr 5, 2006 01:09 PM
beaumontmetal
Jul 21, 2003 12:54 AM
