Sputtering & Jerking when engine is cold
Old Aug 26, 2010 | 10:48 PM
wilson5excursion's Avatar
wilson5excursion
I have a 2000 Ford Excursion 6.8L V10 with 168,000 miles. I start it when it is cold it sputters and jerks after it warms up it quits doing it. My husband had a mechanic hook it to a computer and nothing showed up. He thinks it's something with the transmission. He has changed all spark plugs and the coil packs look fine. A new fuel filter was put in last year. Also he just put all new screws, nuts, & gaskets on the driver side manifold. It had shifted and was causing fumes to go inside. Does anyone have any suggestions? Thank you for your help.
Old Aug 27, 2010 | 03:16 AM
jh818's Avatar
jh818
Check your idle air control valve (IAC valve). What this valve does is it opens when the engine is cold allowing more air to flow into the throttle body...thus allowing it to warm up faster and prevents it from stalling. That is why when you start your engine when it is cold, the RPMs are high. As the engine warms up, it slowly closes shut and your RPMs drop to normal.
When this valve sticks in the closed position, your idle is low and it sputters when cold. As it warms up, it is already in the closed position, thus the normal idle.
This valve is located at the throttle body. Hope this helps.
This problem will not trigger a code or Check Engine Light.
Old Aug 27, 2010 | 05:21 AM
Monsta's Avatar
Monsta
Sit. Stay.
Here it is.
Old Aug 27, 2010 | 07:18 AM
wilson5excursion
Husband took the iac valve out and saw that it was stuck. He cleaned it and fixed it to were it wasn't sticking. The excursion is still sputtering & jerking when cold. We noticed when it does it the rpm's are jumping around.
Old Aug 27, 2010 | 08:37 AM
jh818's Avatar
jh818
Does the sputtering and jerking when cold occur when the transmission is in Park or when it is in gear?
I would still suspect it's the IAC valve. It was stuck. Perhaps it's defective?
Were all the rubber boots replaced when the spark plugs were replaced?
Old Aug 27, 2010 | 09:04 AM
wilson5excursion
It only jerks when it is in gear. Husband says rubber boots were not replaced when new spark plugs were put in. What happens if the rubber boots are bad? Should they have been replaced?
Old Aug 27, 2010 | 09:13 AM
perryg114's Avatar
perryg114
I expect it is still the IAC motor. It gets stuck over and over again so unsticking it once is not going to fix the problem. Once it sticks it will probably continue to stick. Does the problem stop when you hold your foot on the gas? Mine did the same thing. It would stick when cold and the engine did not have enough fuel/air to run.
Perry
Old Aug 27, 2010 | 09:19 AM
wilson5excursion
Yeah when I press on the gas it eventually stops. I will have him buy a new one and hopefully it will quit. I love this vehicle and I want it to last forever. The couple we bought it from never did any maintenance so we have been doing everything to keep it up. When my husband changed the spark plugs it he noticed it still had the original spark plugs in it!!
Old Aug 27, 2010 | 09:47 AM
jh818's Avatar
jh818
You should replace the rubber boots for the spark plugs. They keep water and debris out of the spark plug area. Accumulation of water could cause corrosion and make it difficult to remove the spark plug. A crack in the rubber boot could cause an arc (grounding out) where the spark plug will spark outside, not inside.
I would still replace the IAC. It's not that much. Pep Boys had one for under $50 IIRC.
Old Aug 27, 2010 | 01:10 PM
Monsta's Avatar
Monsta
Sit. Stay.
So when you first start it, it starts and idles fine in Park?
Old Aug 27, 2010 | 01:36 PM
perryg114's Avatar
perryg114
Well the idle servo is going to add throttle as load is applied to the engine. If you put it in drive and the servo is not working it might stall the engine or cause it to run rough. Also the throttle position sensor could be flakey causing the IAC motor to deactivate. I think the V10 uses the throttle position sensor only to detect if the accelerator pedal has been pushed. Have you pulled the codes on the computer? Any autoparts store can do this for you.
Perry
Old Aug 28, 2010 | 03:43 PM
wilson5excursion
Now it's doing more jerking than stalling. It does it while i'm driving, but it the jerking isn't causing the ex to stop. It was hooked to a computer but didn't show any codes.
Old Aug 29, 2010 | 12:10 PM
TeamMudd's Avatar
TeamMudd
ok, this is a wild shot BUT, read over my situation that i had with spark plug boots. i was having a shudder/stalling/jerking issue as well. here's what i went threw chasing it! its long, i know but it might be somewhere to start!
https://www.ford-trucks.com/forums/9...long-post.html
what are the symptoms when you come to a full stop at a red light? some of the "jerking" you could be feeling is the Torque converter trying to fully lock up (like it's in OD at road speeds). if the Torque converter is getting an extra ground signal (ie a spark plug arc, or even a bad alternator diode) it will "think" that it needs to lock up because a ground connection is being completed.
if no codes are present, i'd think you have a ground issue.
Old Aug 29, 2010 | 07:37 PM
UrbanXX's Avatar
UrbanXX
TeamMudd has stressed a very good point about the torque trying to lock up.
My Excursion did the same thing only not as bad in a round about way.
I changed the plugs and checked the boots replaceing 2 boots. Sometimes you can look at a boot all day long and not see the problem. The best way I know to check a boot is to squeeze it and if you see any cracks replace it.
This is what I did and the problem was solved. Its been over 2 months and no problem at all.
Old Aug 29, 2010 | 08:28 PM
wilson5excursion
We changed the IAC Valve and the sputtering stopped. The jerking isn't coming from the motor. Last night it started to jerk and my husband pushed the O/D button and it quit jerking?? Does this mean anything?
