Inline oilcooler
Old Feb 17, 2003 | 09:58 AM
steve miles's Avatar
steve miles
Inline oilcooler
I just purchased a used F250 with a 351w in it and I went to change the oil and noticed that a stock FL1-A filter won't fit due to a inline oil cooler (I think) installed in front of the oil filter. It is inline from the bottom radiator hose. Am I correct in guessing this is a aftermarket part and is not from the factory? Is it worth leaving on? There used to be a plow on the truck and I assume they used the truck for business purposes. I don't plan on regularly hauling heavy trailers or big loads.
Old Feb 18, 2003 | 10:28 PM
kopfenjager's Avatar
kopfenjager
Thumbs up Inline oilcooler
This is a 351M forum not a 351W. That aside, yes I think you are correct in your assumption.
Old Feb 19, 2003 | 10:23 AM
EPNCSU2006's Avatar
EPNCSU2006
Inline oilcooler
I think some 351W's had a factory oil cooler on them. Where do the hoses go?
Old Feb 19, 2003 | 10:25 AM
steve miles
Inline oilcooler
The hoses are passive, inline between the return hose on the bottom of the radiator and the water pump return.
Old Feb 19, 2003 | 09:28 PM
ecarter50's Avatar
ecarter50
Inline oilcooler
Factory 351w oil cooler was started around 94.
Old Feb 20, 2003 | 06:14 AM
steve miles
Inline oilcooler
What motorcraft oil filter will fit. FL1-A is too long.
Old Feb 20, 2003 | 06:35 AM
1993F150XL's Avatar
1993F150XL
Inline oilcooler
I went to motorcraft.com & did a search. If your truck is a 1994 (I just picked a random year), it lists part# FL-820S. You can use the link to verify for other years. I hope this helps.
Really?
