Can I use a non ABS axel on a 94.?
I can't see why it wouldn't work. The effect would essentially be the same if you disconnected the sensor (which is what you'd be doing). The braking system, without a sensor reading will (or should) still function like a standard breaking system. The only drawback I can think of would be a perpetual ABS light on the dashboard. That little problem is easily solved by removing the indicator lamp.
My wife's '92 Cavalier had the rear sensor(s) disconnected completely because they were screwed up and a Cavalier isn't worth the time, effort, or money to fix bad ABS sensors! The car actually handled BETTER after the sensors were gone! (Or should I say, as well as a Cavalier ever handles).
A ha I found it
https://www.ford-trucks.com/dcforum/bigbronco/2059.html
Originally posted by marriedguy1
A ha I found it
A ha I found it
I strongly suspect that F6529E731AA (which doesn't even look like a proper Ford PN) is just the '87-92 t-case VSS which was ONLY used for cruise and early E4ODs. It won't operate the ABS, the '93-up cruise, or the PSOM ('93-96 speedo).
The speedo hole on late-model t-cases is filled with a plug and the retainer bolt hole isn't drilled or tapped.
