Flushing Brake System Qs
Old Aug 25, 2010 | 08:03 PM
Quick444's Avatar
Quick444
Another on the fly post from my phone. Heading to towwn to pick up a rotor and maybe get my truck back on the road tomorrow. How much fluid should I buy to flush the system and fill it? I'm also putting new pads all the way around and believe I need to burl the new pads in. Do I need sandpaper to do this properly?
Figure while I'm doing all of this that I should flush my power steering system how much and of what should I get?
Thanks for the answers n advance, I don't have a way to search the forumsright now.
Old Aug 25, 2010 | 08:35 PM
F350-6's Avatar
F350-6
The big ( I think it's quart) bottle of brake fluid they sell is not enough to do the flush. The big bottle and one little one is usually enough, but I'd get 2 of the big bottles.
Power steering takes ATF. Many of us use synthetic. 3 or 4 quarts should be enough for a flush there.
Old Aug 25, 2010 | 08:52 PM
damicofuel's Avatar
damicofuel
I did the powersteering flush but not the brake flush, there are good write ups on it, and I did use synthetic and made a great difference!
Old Aug 25, 2010 | 10:50 PM
Stewart_H's Avatar
Stewart_H
Exactly what Chris posted, a big bottle and a small will suffice, but play it safe and get two of the big.
As for bedding in your pads, you don't use sandpaper, it's a series of braking from different speeds that beds the pads to the rotors.
Here is the instructions for Hawk LTS pads:
Stewart
Old Aug 26, 2010 | 08:38 AM
DieselCamper01's Avatar
DieselCamper01
A little late on this maybe but I believe the break in method is different depending on whose pads/rotors you are using
Old Aug 26, 2010 | 08:47 AM
Wayne64SS's Avatar
Wayne64SS
yes the break in method for pads for different for EACH brand / line of brake pads. Different compounds operate effectively at different temperatures. This is the whole reason for the burnishing. However, I usually do a bunch of stops from 30-35 to 0 then one or two from 50-0 and let the brakes cool. I've never had a problem.
Old Aug 26, 2010 | 07:20 PM
Quick444's Avatar
Quick444
Picked up 4 small bottles of dot 3 &4 synthetic fluid and I still have a 5th bottle of dot 3 that I will start the flush with.. on my hawk pads, the sandpaper mention was on the installation section of the same box posted above. Getting to it right now.
02GrayPowerStroke
Sep 16, 2018 02:30 PM
Eallend7
Mar 6, 2013 07:27 PM
davbeisner
Nov 28, 2012 03:23 PM
