1978 - 1996 Big Bronco
what tranny is it
Old Aug 25, 2010 | 11:25 AM
jhoopman86's Avatar
jhoopman86
what tranny is it
i have an 86 bronco with tranny code K. what tranny is it?
Old Aug 25, 2010 | 12:24 PM
Kemicalburns's Avatar
Kemicalburns
what does the shifter read on the column? can you take pictures and post them?
Old Aug 25, 2010 | 01:11 PM
mprice's Avatar
mprice
How many bolts on the trans pan?
C6=17 & one side has a jog in it
AOD=14 & two sides straight, two sides have a bend
LMC Truck Parts - Page 9
Old Aug 25, 2010 | 06:10 PM
jhoopman86's Avatar
jhoopman86
does the aod have a plug on the top? it is a 14 bolt approx 13"x15" with a hump in the center of the pan
Old Aug 25, 2010 | 07:30 PM
greystreak92's Avatar
greystreak92
Does it shift twice or thrice when you drive it? Twice = 3-speed (C6) Thrice = 3-speed+overdrive (AOD).
Old Aug 25, 2010 | 08:15 PM
jhoopman86's Avatar
jhoopman86
yes i can take pics but i am not sure what numbers u r located.
i am not sure how many times the tranny will shift it wont shift into anything but reverse and first. i got it there was n extra transfer case in the back looks to be the original the one that is in it now looks to be bigger then the origonal. u can tell that someone has replaced both the tranny and the transfer case with ethier a newer or a bigger one it should have efi but has a carb which is fine with me but cant get it to shift having problems in the rod that goes from the carb to the tranny got it hooked at carb end but not sure linkage is right on the tranny.
