Ring and pinion sets
Old Aug 25, 2010 | 10:14 AM
Hiflyer746's Avatar
Hiflyer746
So I finally ripped some teeth off my ring gear the other day while pulling my trailer home. . . . Luckily I made it back home! However I'm having a very hard time locating a 10.5 ring and pinion set in 3.73 gearing. The only distributor or manufacturer I've seen is yukon gear, and they are out of stock on this set. Suggestions?
Tim
Old Aug 25, 2010 | 10:21 AM
SuperDoodie's Avatar
SuperDoodie
Randy's Ring & Pinion. The Differential Experts. Auto Parts & Services.
Old Aug 25, 2010 | 02:16 PM
tinker934's Avatar
tinker934
gears
did you find your gears yet?
Old Aug 25, 2010 | 02:20 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
I have an extra set in great shape if you want them... Let me know.
Old Aug 25, 2010 | 05:31 PM
deemac's Avatar
deemac
I just did this in my truck, it is 3.73 as well. All you need to do is get the 3.73 ring and pinion for the older 10.25 sterling and an install kit for a 10.25 as well. The pinion bearings are different for the 10.50 and the 10.25 so ya, just get the 10.25 bearings(install kit) and it'll be fine. Mine is working great and that is what i did.
Old Aug 25, 2010 | 11:22 PM
Hiflyer746's Avatar
Hiflyer746
I have not got them yet. Will check the link. I'm probably going to reuse the bearings as i changed them when I installed the locker. That is assuming they aren't damaged.
Clay. . . what were they out of? Abuse? Miles? Cost? Thanks.
Tim
Old Aug 25, 2010 | 11:24 PM
Hiflyer746's Avatar
Hiflyer746
Also. . . randy's is out of stock on the 3.73 ratio.
Old Aug 25, 2010 | 11:32 PM
Riffraff Diesel
PREMIUM SPONSOR
PM Sent...
Silvestris
Dec 10, 2012 08:07 PM
carlmaass
Nov 13, 2011 11:53 PM
nickelndime79
Jul 15, 2011 10:21 PM
eddieburnsii
Jun 30, 2007 09:02 PM
therigwelder
May 27, 2005 07:24 AM
