Why does everyone hate the 6.0L?
Regards
The only mod on my 6.0L is that it is straight piped and honestly it has done nothing but improve the truck in my opinion...
Were there some trucks that were just bad out of the "box", I would be a fool for not thinking that it wasn't atleast possible and not all of those trucks were due to owner and/or tech incompentence. However, here is the rub, how do we seperate those that are legitimate "evils" of the 6.0 engine and what can be attributed to an outside force? Especially considering that the outside force(whatever or whomever it may be), may not have even been connected to that?
I can go on and on about this. No one, unfortunately, will be able to offer a conclusive determination in this case. Sure some will think that they have, but they really won't be able to. Too many things went on that makes it very hard to say with the force of logic behind it one way or the other conclusively.
I think the higher horsepower and extra heat produced on a cooling system that is almost "maxed out" is what makes the engine so much more prone problems in the pickup truck.
We have customers of 2003 model 6.0L Internationals pushing 200,000 miles and have never had a cylinder head off.
We also never change oil coolers because we have never had a problem with them.
Most common problems are turbo, EGR and fuel system problems, just as the pickups have.
So whats the deal?
The only f'ing complaint I have is why the hell did they make it so dang hard to R&R the heads. I would have studded this thing years ago if I dodn't have to remove the cab......and yes I know there are other ways.
Take Care
Joe
Sometimes there isn't much other way around it without increasing the cost of the vehicle due to changes required for accessibility and maintenance. Function and fashion are the most important I have come to learn. They usually override any other aspect of how a vehicle is put together. It has to look good, and it has to work, thats all that 90% of car owners need, and want. It only comes to nip them in the butt when they wonder why the bills for maintaining and repairing the vehicle are so high.
Like I said, that was in 2009, but I doubt those sales came overnight, so certainly they have been selling well for quite some time.
Lets face it, most people get rid of their trucks/cars when they start having problems with them. While I don't think the 6.0 is the worst engine (maybe the worst PSD), I think you are far more likely to find a bad one in the used market than say a bad 7.3 or 6.4 (depending on what side of the scale you are on). I think the 6.0 was running near it max given the hardware it had, and when a "weaker" one came off the line, it may have been pushed to much. This is probably the reason you see people that have had all new engines before 15,000 miles. Combine that with the fact that thing can get very costly very quickly, and you have problems.
Use the OP's EGR for example, say he didn't clean it. Eventually other parts would have started to fail and his $2 fix would have turned into a $2000 fix or more.
People want to just put fuel in the vehicle and go. They don't want to take the time to maintain many different parts of it. Most people I know barely change the oil when they are suppose to in their gas cars/trucks. This is also a reason I went with a gas engine. I'm lazy, don't want to deal with urea cartridges and lots of maintenance, although the number one reason was cost of the PSD.
If I was to actually be able to get to the nitty gritty of a lot of claims that people have of their crappy 6.0s, I wonder how many of those would seem legit versus those that could have another possible alternative as to why their vehicle went south.
Is it possible that the 6.0 is truly a lemon of an engine, yes it is possible. Will anybody be able to conclusive say that's so? No, a lot of people might think they can, but they really can't. Too many other variables out there that people can't get the true numbers as to legit claims versus non-legit(for whatever reason).
These are high performance engines that need to be kept up as such. Not any different then Testirosas or Massarates(I know I misspelled both of those) and those cost a helluva a lot more then ours do.
Some of the extra stuff that I would suggest for 6.0 users, I would actually suggest for people to use no matter what the truck is(not so much cars, but trucks yes). Gauges being the biggest one. I have had major repair work on all stock 5.9 and a 7.3 and I would have probably known sooner of what was going on if I had gauges like I do on my 5.4 and on my 6.0. Upkeep would be another thing that I would be religous on. I don't do fuel and oil additives and I actually am not an advocate of the coolant filter.
That's just my take on it anyway.
Getting back to an earlier post about the oil cooler, someone said that the oil coolers were made differant for the International engine. Assuming they allowed more or less restricted flow. I guess they do not interchange if this is true, or people would be doing the swap, correct?
Now it could still be my problem, but I actually haven't had that happen(yet) until I get some yrs on them.
Let's be clear, I agree with most of what you say here. I've not owned a 6.0, I did have a 7.3 before the V10 though. I think quite a bit of the problem here is that the 7.3 could take quite a bit of abuse where as the 6.0 could not. People bought the 6.0 thinking it could be chipped and abused like the 7.3 and be fine. Then they where surprised when things were not fine.
Again, you buy these cars knowing what you are getting into, most people have no idea of the maintenance behind some of these trucks. I know a Ferrari 360 clutch costs about $5,000 and it needs one every 15,000 miles or so, and most people in that market know that too. Most first time diesel owners don't realize everything that goes into it.
