1994 clutch issue
Old Aug 23, 2010 | 08:28 AM
1994F2507.3L's Avatar
1994F2507.3L
1994 clutch issue
when the clutch is cold no problems after a drive and everything gets warm and the clutch is released toward the top of the pedeal (almost fully released) i hear a popping sound coming from inside the tranny right about where the linkage goes in. any ideas what causes this do i need to worry? its a ZF5 it operates correctly catches and realeses fine but the noise is worrying me
Old Aug 23, 2010 | 10:48 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Throwout sticking on the nosecone, Throwout fork not seated correctly on pivot, cracked/broken bellhousing are the things I'd be looking for.
-Enjoy
fh : )_~
Old Aug 23, 2010 | 11:11 AM
Dave Sponaugle's Avatar
Dave Sponaugle
How long since the fluid has been changed?
Souinds like something I would get checked out while it is still probably rather cheap to fix.
Right now you may be looking at a bushing or bearing, later when it fails you will most likely be looking at a lot more parts.
Old Aug 23, 2010 | 11:36 AM
1994F2507.3L
how do i check those parts ive never messed with a transmission before the fluid change..... i honestly don't know it was full when i got it i have been checking the fluid and its full still but don't know how old it is
Old Aug 23, 2010 | 11:56 AM
Dave Sponaugle
Fluid in the transmission, transfer case and axles needs changed just like it does in the engine.
I change my fluids every spring, all of them after a hard winter of plowing snow.
If you have never had a transmission apart, a transmission shop that knows what they are looking at would be your best bet.
Old Aug 23, 2010 | 03:46 PM
1994F2507.3L
stopped at the ford dealer in town on the way home from work today and they said it's either got to be the throughout bearing or the clutch fork it wearing out after listening to the noise.
guy at autozone said the same thing probably bearing or clutch fork....
luckily both are relatively cheap bearing 28 fork 31
won't be able to get the tranny out until this weekend to replace the parts buddy and his dad have done it before so im gonna be learning this weekend is it ok to drive it still shifts smoothly haven't had any real issues with it yet
Old Aug 23, 2010 | 10:20 PM
poocher pup's Avatar
poocher pup
you never know could let go backing out of driveway going slow or on highway at 70 chance you take. does it make any difference if you take it out of gear release the clutch and let truck just roll at speed.
Old Aug 24, 2010 | 09:16 AM
1994F2507.3L
it operates normal i haven't had any trouble with it i can feel it in the pedal very very softly like almost non existant and at road speed (45-70) i can;t hear the noise when releasing the clutch.... that could be because of the road noise but below that i can hear it but it still glides in and out of gear smoothly just like normal and the clutch catches and releases in the same spot as always.... im kinda leaning toward the clutch fork bein out of wack just a little.... but i'll probably replace the bearing and fork together for the piece of mind.... and ill be able to look at the clutch while im in there i guess.... iv'e never actually seen a clutch thats been used and only seen one new one so it'll be an experience for me.... also i was told that when replacing the clutch (hopefully not anytime soon) the flywheel can be turned rather than replaced..... true or not???
Old Aug 25, 2010 | 09:26 PM
Dave Sponaugle
ZF 5 transmissions had dual mass flywheels.
I have never heard of anyone resurfacing a dual mass.
Old Aug 25, 2010 | 09:30 PM
1994F2507.3L
what is the difference i know well ive been told there better for towing but what makes them better i looked at the price of the flywheel for one and wow......
Old Aug 26, 2010 | 08:14 AM
1994F2507.3L
is this the set i need to convert to single mass flywheel clutch system?
cost aside is this a wise decision?
Duralast/Clutch Set-Matched (NU31411LFW) | Clutch Set-Matched | 1994 Ford F250 3/4 ton P/U 4WD 8 Cylinders M 7.3L Diesel | AutoZone.com
Old Aug 26, 2010 | 08:41 AM
farmert's Avatar
farmert
Yes that is the set you need. I used the conversion from NAPA, but I would guess that the AZ parts would be the same. I have done this to 5 different trucks 2 IDIs and 3 early strokes with NO ill effects.
Old Aug 26, 2010 | 08:47 AM
1994F2507.3L
well hopefully i get some money this weekend to start saving for the conversion kit..... hauling hay all weekend.... not with my truck though now.....
Old Aug 26, 2010 | 11:27 AM
Festus Hagen
Methanoholic
Any ill affects of a SMF conversion will takes years to show up ... a SMF will beat a ZF5 to death!
But not over night or in a couple years!
-Enjoy
fh : )_~
Old Aug 26, 2010 | 01:17 PM
1994F2507.3L
is that inevitable or avoidable depending on driver habit? i don't slam **** the truck
