valves
Old Aug 23, 2010 | 02:50 AM
beau30's Avatar
beau30
valves
I replaced the head on my 1990 f150 and now it wont run righ,t the plug wires are routed correctly and dont know what else the problem could be. some one told me you cant adjust the valves so i didnt, could this be the problem?
Old Aug 23, 2010 | 05:00 AM
Slip ford man's Avatar
Slip ford man
Could be...normally you would check the valve lash, and make adjustment's to clearance as needed
Old Aug 23, 2010 | 12:10 PM
Conanski's Avatar
Conanski
Valves are not adjustable on these motors and if you used all OEM parts there is no reason it should need adjustment. What motor do you have and what about the way it runs isn't right?
Old Aug 23, 2010 | 03:30 PM
Slip ford man
I believe that the adjustments are made by inserting a longer or shorter OEM push rod, depending on the clearance reading during the setup. I don't think that you can use the same push rod without at least checking for minimum clearance requirment. For example the 5.0 engine requires 0.071-0.193 in.with a desired 0.096-0.165 in.
Old Aug 23, 2010 | 06:21 PM
beau30's Avatar
beau30
its an xlt lriet and i have to advance the timeing way out to get it started and then it revs real high i can bring the timeing back down and it will slow down and remain running but it back fires from the exahst and throtel body and shakes real bad. does anyone think the EGR valve could be the problem?
And thanks SLIP FORD MAN i love my scrap heap to it keeps me buisy and out of truble
Old Aug 24, 2010 | 07:36 AM
Slip ford man
Have you checked for a vacuum leak, what engine you got there?
Old Aug 24, 2010 | 08:25 AM
Conanski's Avatar
Conanski
Sounds like the plugs are wired wrong, what engine is in it and what year is the truck?
Old Aug 25, 2010 | 12:50 AM
beau30's Avatar
beau30
it is a 1990 ford f150 XLT Lairett ext cab and has a straight 6 4.9
