Its dark without headlights...
Old Aug 22, 2010 | 08:00 PM
officer316's Avatar
officer316
I have a 1996 F350 7.3 powerstroke dually. I'm having problems with my headlights. When I have them on and use turn signals they will turn off. If I pull the dimmer switch they will sometimes come back on and sometimes they won't. Any one help? PLEASE...
Old Aug 22, 2010 | 09:10 PM
danger-ranger93's Avatar
danger-ranger93
could it be your actual dimmer switch? just thinking out lound but thats what comes to mind first
Old Aug 22, 2010 | 10:34 PM
Encho's Avatar
Encho
The Southernmost Mod
I bet you can solve your problem in the fuse box, try doing some checks in there. If that doesn't do it, then go for the wiring (wich i suspect isn't the cause, seeing it happens on both headlights ATSM).
Old Aug 22, 2010 | 11:53 PM
truckrider814's Avatar
truckrider814
I had the same problem, and it turned out to be the headlight switch had gone bad.
Old Aug 23, 2010 | 01:41 AM
LCAM-01XA's Avatar
LCAM-01XA
I place my bets on the dimmer switch, since it also doubles as a turn signal switch, and is to my knowledge the only component in which the two otherwise independent circuits intersect...
