FE vs. Windsor vs. Cleveland
Old Aug 22, 2010 | 03:47 PM
Joe Carson's Avatar
Joe Carson
Still looking for a 360/390 for my '74 Hiboy- last option fell through. I realize putting in what came out is the best option, but I've located several buildable or even rebuilt motors from other engine families. Are these others just "bolt up and go", what are pros and cons?
Old Aug 22, 2010 | 04:05 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I don't remember, but do you have a manual or automatic transmission?
The big thing with engine swaps are bellhousings/ auto trans and engine perches.
Also oil pans, whether front sump, rear or dual sump.
Josh
Old Aug 22, 2010 | 06:10 PM
Joe Carson's Avatar
Joe Carson
I have a 4 speed. I went from a 300 I-6 to a 400 in a '76 f150 and remember lots of challenges; hoses, mounts, etc. I didn't know if things changed much when dealing with the F250. Why did Ford discontinue the FE? Is there something integral in the newer engine families that make them better?
Old Aug 22, 2010 | 06:18 PM
Bullitt390's Avatar
Bullitt390
As the folklore goes Ford had to drop the FE engines due to the new emissions limits that were being enacted.
Which doesn't make much sense in my mind, why create and develop an entirely new engine family than to just revise the cylinder heads and intake manifolds for an engine that had done an honorable job since 1958?
Which is even more puzzling given the 351M/400 was dropped only 4 years later after the FE was considered extinct.
Not one of Ford's better decisions in history no doubt.
Josh
Old Aug 22, 2010 | 07:52 PM
first today's Avatar
first today
I have to say, stock for stock, I love a 390. They take tons af abuse and keep on rolling. I never had that luck with my 400, 302, or 300 engines.
Old Aug 22, 2010 | 09:08 PM
hasteranger's Avatar
hasteranger
the windsor and cleveland motors weren't found in dents originally.... the FE motors were. if youre swapping in something why not a big block?
Old Aug 23, 2010 | 01:20 AM
Joe Carson's Avatar
Joe Carson
Sorry for the ignorance, can someone define "dent"? Also, I'm not opposed to the 360/390, It's just been a little challenging finding a buildable motor. I was only checking options. It seems there are more 351/400's available. In highschool, I worked in a Ford parts dept. and we supplied a lot of 330/359 motors for Uhaul's F350-600 commercial fleet.
Any thoughts on those?
Old Aug 23, 2010 | 01:53 AM
Kalve's Avatar
Kalve
check with junkyarddog & craigslistcrawler for them
Old Aug 23, 2010 | 02:49 AM
sdg0080's Avatar
sdg0080
i've got a 361/391 complete i know its the ft motor but you can "convert" it to a 390 with a differant crank, or turn the nose down on it. and change the timing cover. or i may know of a running 390 a friend may be willing to part ways with. i dont know where you are at however...lol if you are thinking of any kind of MPG's forget about the 390...i have a built one in my 73 and it will move anything you could ever want to hook up to. but i get 7.5-8mpg on the highway loaded or empty. i've put 3K lbs in the back of the truck and it gets the same as if i run it empty. however it did ride much smoother...lol
Old Aug 23, 2010 | 07:33 AM
doug70's Avatar
doug70
I have a low mileage 360 that I took from my 73 F100. I went 351W and NV4500.
I'm in west Texas.
Doug
429 merc
21
Jun 30, 2015 06:37 PM
JRS2
Jun 12, 2015 12:25 PM
calazo
16
Jun 23, 2004 04:46 PM
fireball69
Modular V8 (4.6L, 5.4L)
Feb 22, 2004 07:44 PM
84Maztang
Jun 13, 2003 04:58 PM
