Please, listen to the guys above...........they are garbage, put it on the workbench, hit it with a hammer a few times............you will still get the same level of improvement as if you installed it.
The EEC is located in the drivers side kick panel but.... you have to pull it out from inside the engine bay after disconnecting the wiring harness. It will be the long and narrow connector beside the round or square chassis harness connector.
