1993 Hypertech placement
Old Aug 22, 2010 | 01:04 PM
Jonnyz's Avatar
Jonnyz
Ok, where the heck would you install a Hypertech chip or module in a 1993 F-150?
Old Aug 22, 2010 | 01:47 PM
rla2005's Avatar
rla2005
First question is why would you want to? Waste of money.
Old Aug 22, 2010 | 02:07 PM
Conanski's Avatar
Conanski
The only place it can be installed in the vehicle is on the EEC, but the only place it should be installed is in the trash can.
Old Aug 22, 2010 | 02:57 PM
Jonnyz's Avatar
Jonnyz
I give, where the heck is the EEC located?
Old Aug 22, 2010 | 03:39 PM
Old93junk's Avatar
Old93junk
Please, listen to the guys above...........they are garbage, put it on the workbench, hit it with a hammer a few times............you will still get the same level of improvement as if you installed it.
Old Aug 22, 2010 | 04:15 PM
Jonnyz's Avatar
Jonnyz
Duly noted, I fully intend to remove it, I just need someone to tell me where the dang EEC is located.
Old Aug 22, 2010 | 04:28 PM
Conanski's Avatar
Conanski
The EEC is located in the drivers side kick panel but.... you have to pull it out from inside the engine bay after disconnecting the wiring harness. It will be the long and narrow connector beside the round or square chassis harness connector.
Old Aug 22, 2010 | 04:51 PM
Jonnyz's Avatar
Jonnyz
You the man Conanski, I appreciate your knowledge.
