Bought My First Truck
hello everyone,
I just bought my first truck yesterday. 2008 F-350 Harley Davidson. It has about 128000 km on it (79500mi) and its my first diesel. I filled it up yesterday and used Howes Lubricator for the first tank. I live in BC Canada and I can only get B5 Diesel. Has anyone had experience with Howes Lube products? I plan on using "Howes Diesel conditioner & anti gel" from now on. Would anyone recommend and additives instead of Howes? Also Oil change is coming up... I am set on going synthetic just dont know which brand yet.. should i change the fuel filters also? I will for sure drain the water separator. Any Tips n Tricks would be appreciated.
Don't know anything about the additives you are using. As far as oil is concerned I would ensure it is CJ-4 rated diesel oil.
Stay away from AMSOIL.
I would change the fuel filters if you don't know the history.,...might do it anyway.
Change them at 10K miles, don't know the KM conversion.
Do the oil at 5K miles. Use only the motor craft filters.
BTW..pics would be nice!
Nice Rig!! i would switch to diesel clean im from ontario and our local shell dealer carries howes and i know alot of people who have had trouble with that brand specially in the winter months
also get some black filter eliminator from DSG in sask the internationals are known for the black filter problem i use this product in my bulk tank
sorry to ask but whats black filter eliminator? i will look into diesel clean thanks for the tip.
i was just under my truck and noticed oil all around the oil drain plug. it isnt leaking at the plug but its all around the pan where it is bolted up. I will get some pics up later because im probably wording this wrong. but there was oil around the pan and the bolts. is this a serious problem? i checked the oil level and its fine, it could of been from the previous owner when he got all the lines flushed and everything?
I have heard of it and used to use it. It seemed good. Navistar recommends it for their engines ( at least they did last I knew ). Only reason I changed additives was price. Diesel Kleen gave me pretty much equal results at a better price.
thanks david.
in the future i want to do a DPF and CAT delete. i just dont know if i will be able to do it myself. anyone live in BC, around abbotsford/surrey area that can give me a hand? CAT and DPF delete with spartan tune and leaving the EGR is fine right?
what do you guys do to get the most turbo whistle?
Pew Professional
09-08-2016 06:56 PM
lubee84
49
04-11-2012 05:46 PM
fordff
12-04-2010 08:27 AM
WGP1973
S. California Chapter
25
11-06-2010 10:57 AM
