manual GP's
with a nice rig like yours,and the newer system it would be nice to keep it original.
the newer system works so dang good.be a shame to lose it to a manual glow.
Remove the white wire off the relay, attach a wire to that relay terminal and run it into the grill to one leg of a button, ground the other leg...
Quick, dirty, no damage temporary manual glow plugs for the 87 up (New style Controller)...
-Enjoy
fh : )_~
More than one person in the forum has had problems with the ground wire not making a good connection.
A few people went as far as running a ground wire from the battery to the controller ground, with great results.
Even completely hot, the controller still cycles. I could run it up a hill, turn it off at 200F, let it sit for a second, restart it and it goes though its heating cycle. Now i know what the wife meant. She took it out the other day to pick up some hay, no fellas she didnt hurt it. But she said she was watching for irregular things and she saw it doing it, i noticed this am after getting some fuel. only off for about 5 minutes and it was still at 190F so why is it glowing for about 8 seconds and afterglowing when it is warm? the cold advance works well still, just dont know here. As usual, thanks for the help!
(haynes diesel book 10330)
a)check afterglow voltage- remove harness plug at the control switch.start engine and check for voltage at control switch harness.
b)pull harness connector from after glow relay-turn the ignition switch OFF.disconnect wiring at the after glow relay and check connector terminal #1 for ground.
(you'll see a connector with 4 pins inside.with the fat side on the bottom.#1 is the very top.#2 just below it,#3 down in the fat part on the left,and #4 is to the right.......hmm k? lol.hope i descried the pic good enough.)
if the ground is not ok,repair or replace wiring as required. --- this should test good,because you said you ran a devoted ground.but don't skip checking again.
if the ground is ok,turn the ignition switch on and check for voltage at terminal #2.
11 volts is the minimum acceptable reading.
if the reading is less than 11 volts,repair the wiring as required.
if the voltage was a minimum of 11 volts,start the engine and check for voltage at terminal #3.
the reading should be 6.5 to 7.5 volts.
if it is not,repair the wiring or alternator as required.
if the harness connector checks ok,check for resistance between connector terminal #4 and control switch terminal #1.
(the harness connector has 6 ports.looking at it,with the longest side on your right,which has the most ports[4] )
#1 is top right.ok?
if resistance is less than 1 ohm,replace the afterglow relay.
if resistance is is 1 ohm or greater,disconnect the chassis-to-engine glow plug harness connector,and check for resistance between terminal #1 of the chassis connector and after glow relay connector terminal #4
(you know where #4 is on that,as described above ok?)
if resistance is less than 1 ohm,replace the plow plug harness.
if it is 1 ohm or greater,repair the vehicle wiring (haha! oh boy.in other words if this is the case,your on your own finding the problem.)
good luck!
