what tranny fluid do you guys use im having a hard time finding mercon sp. did not try the dealer though. All i found was mercon max life in the red bottle by valvoline said it was compatible for vehicles requiring mercon sp. What does the dealer use??? and what is the part # for the tp filter by the cooler thanks in advance for thoughts and suggestions.
Ford 6.0 Liter Turbo Diesel External Transmission Filter
Motorcraft 3C3Z-7B155BA (FT-145) Comes Without O-Ring Price 22.04
NTZ: NTZ-09-C09B Comes With O-Ring Price 12.99
NTZ make Ford Motorcraft Trans Filters
Sorrey one more question how much fluid have you been putting back in with the drain plug pulled and a new filter?? my chilton book is unclear it states to add 6.5 qts run it through all the gears and add fluid accordingly. The book covers 6.0L as well as the 7.3L and doesnt mention anything different between the model years.
The correct way to change your trans is a hot flush by your dealer There is a thermostat in the trans and all the fluid cannot be drained. The way I did mine I drained the pan about 7-8 quarts will come out. I did that once and than 2 more times at 3 month intervals. Now every 6 months or so I drain it an add 7-8 qts. or whatever comes out. I also change the filter 1 a year regardless of mileage.
