BYPASS FUEL SELECTOR SWITCH
Old Aug 21, 2010 | 10:00 PM
Rick Wallace's Avatar
Rick Wallace
Any body ever bypassed the FSS and let fuel draw from both tanks? Of course with an E-lectric fuel pump,and would the gauge be correct/
Old Aug 21, 2010 | 10:06 PM
oldkountryboy's Avatar
oldkountryboy
not sure how easy that would be to do, but i know the gauge would not be able to display both tanks at the same time
if you wanted to add another fuel gauge then you could have one for front and one for rear
Old Aug 21, 2010 | 10:11 PM
poocher pup's Avatar
poocher pup
you would be only reading for which ever tank you have switch on as to fuel level. don't know what it would do if one tank was empty and other had fuel if it would suck air from empty tank.
Rick Wallace
Ill have the bed off soon to fix the pick up tubes and replace fuel lines so it will be fairly easy to get to,once im done I dont want to have fuel problems again
Old Aug 22, 2010 | 10:20 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
That would be the FSV (Fuel Selector Valve) not FSS (Fuel Shutoff Solenoid).
-Enjoy
fh : )_~
Old Aug 22, 2010 | 10:28 AM
oreocreaming's Avatar
oreocreaming
if you draw off both tanks then your going to have some issues man. first, as stated your only going to be able to read off one tank. second, since you will be sucking more out of one tank then the other (it will never suck evenly) then when one tank runs out you will be sucking in air and that will get into your system. so its not worth the hassle. one think you could do ( i would if i were trying to get rid of the fsv) is remove the back tank, weld a bung to the front bottom side of the tank and weld a bung to the top passenger side of the front tank next to the pick-up setup. run a nipple and hose from the rear to the front with a ballvalve between the lines. you run just off the front tank, and when its empty just flip on the ball valve. it will fill your front tank and since its a smaller tank in the rear theres chance of overfilling. theres enough drop in there where it will drain the tank in about 10 min. you will just have to remove both caps so it doesnt get pressure in one and vacuum in the other. unless you run a second hose to it at the top of each tank for air transfer.
Old Aug 22, 2010 | 12:36 PM
Rick Wallace
-Enjoy
fh : )_~
Yea that thing
Old Aug 22, 2010 | 12:52 PM
Rick Wallace
OK,,,X that idear,,,thanks
2026 Ford F-150 Lariat: 4 Biggest PROS and 3 Worst CONS
Top 10 Forever Vehicles: Here's What Owners Refuse to Sell!
Top 10 Best Ford Off-Roaders Currently For Sale, RANKED!
Ford Explorer Tremor Review: Best Explorer Ever
10 Cheap Ford Trucks & SUVs That are the Most Fun to Drive!
5 BEST / 5 WORST Selling Ford Models in 2026 (So Far!)
10 Times the Ford Super Duty Let Us Down
F-150 Raptor R: The PROS & CONS of Daily Driving a Super Truck
Old Aug 22, 2010 | 10:41 PM
Dave Sponaugle's Avatar
Dave Sponaugle
For the very small amount of problems the FSV gives, I would not think about trying to run without one.
No way to tell how much fuel you have left in both tanks, no way to direct which tank the fuel is sucking from or returning to without it.
The one on my 86 is getting very close to 500,000 miles, still work perfectly.
Erictusio
Feb 13, 2017 12:58 AM
TerranE
21
Jan 3, 2017 08:43 AM
sgrol
6.7L Power Stroke Diesel
Dec 8, 2016 08:26 PM
twozzie
Nov 15, 2015 08:36 PM
Skip1970
15
Apr 16, 2012 04:27 PM
Slideshow: diving into the PROS and CONS of the 2026 F-150 Lariat.
By Michael S. Palmer | 2026-07-15 11:10:23
These are the vehicles that owners don't want to part ways with, ever.
By Brett Foote | 2026-07-14 16:44:21
Slideshow: Top 10 best Ford off-roaders you can buy, ranked.
By Joe Kucinski | 2026-07-14 16:22:55
Slideshow: a first-drive review of the 2026 Ford Explorer Tremor, off-road and on!
By Michael S. Palmer | 2026-07-07 13:10:58
Slideshow: 10 cheap Ford trucks and SUVs that are the most fun to drive.
By Joe Kucinski | 2026-07-07 10:36:13
Slideshow: 5 best and 5 worst selling Ford models in 2026.
By Joe Kucinski | 2026-07-06 16:48:56
Slideshow: 10 times the Ford Super Duty let us down.
By Joe Kucinski | 2026-07-01 07:42:10
Slideshow: the best and worst parts about daily driving an F-150 Raptor R
By Michael S. Palmer | 2026-07-01 07:35:47
