Sponsored by: Real Truck
question about high idle mod
Old Aug 21, 2010 | 09:51 PM
havns3's Avatar
havns3
can the switch for the high idle mod be a momentary push button or does it have to be a toggle switch. if i am reading it right it returns to regular idle speed when the brake is pushed. so you do not have to turn it off with the switch.
Old Aug 21, 2010 | 10:07 PM
riggz's Avatar
riggz
It needs to be a toggle switch. The brake will disable the high idle, but only momentarily.
Old Aug 21, 2010 | 10:10 PM
c.f.moore's Avatar
c.f.moore
It needs a 12v constant source to set the high idle. Once the source is removed, it returns to normal idle.
If you use a toggle switch, touching the brake pedal turns it off. You can leave the switch on, as the only way for the high idle to return, is if it's in park, with the emergency brake applied.
Good luck
Old Aug 22, 2010 | 07:35 AM
havns3's Avatar
havns3
ok thanks guys. i wasn't sure about which switch to get. i found a really small blue led toggle that i think will work great.
Old Aug 22, 2010 | 07:50 AM
ruschejj's Avatar
ruschejj
I used to just leave it on all the time and anytime I wanted to idle I would just push in the emergency brake, so technically, you don't need a switch at all but I would still use one.
rezrocket6.0
Oct 22, 2013 10:52 AM
roy.prue
34
Mar 2, 2012 08:59 PM
guthrie&co
Dec 30, 2010 11:13 PM
2010F350
6.4L Power Stroke Diesel
Sep 6, 2010 10:45 PM
i eat hybrids
Apr 19, 2010 07:48 AM
