Do i have add a leaf? (pics)
Old Aug 21, 2010 | 07:11 PM
Joelong258's Avatar
Joelong258
The first owner had a 2.5" leveling kit on the front which the guy i bought my truck from took off so it would fit in his garage. My question is is the back of the truck got a add a leaf kit that wasnt taken off as well?
http://i775.photobucket.com/albums/y...1/b0ecb783.jpg
http://i775.photobucket.com/albums/y...1/89314f78.jpg
http://i775.photobucket.com/albums/y...1/34a41d6f.jpg
Old Aug 21, 2010 | 07:45 PM
megawatt00's Avatar
megawatt00
Looks stock to me Joe. Mine is the same way in the rear.......... not for long though.
Old Aug 21, 2010 | 08:44 PM
Joelong258's Avatar
Joelong258
Thats what i was wonderin if it looked like everyone elses. Thanks
Old Aug 22, 2010 | 12:49 PM
megawatt00's Avatar
megawatt00
Your welcome
Old Aug 22, 2010 | 03:04 PM
redfire42's Avatar
redfire42
My 02 has one less spring than yours so maybe someone did add one.
Old Aug 22, 2010 | 04:10 PM
megawatt00's Avatar
megawatt00
I double checked mine and I have the same amount of leafs.
Old Aug 22, 2010 | 06:28 PM
bulla's Avatar
bulla
It looks to me like there is an ad-a-leaf in there. If I'm not mistaken there should only be 5 leaves and 1 overload which is the thick one on the bottom. I didnt notice it in your first pic but in your last pic I could see an extra one in there. How much higher does the back of your truck sit compared to your front?
Old Aug 22, 2010 | 06:36 PM
bulla's Avatar
bulla
My bad I double checked the pic and what I thought was the 6th spring was just the plastic between the springs to quiet down the squeak. Normaly rear add a leaves arent added till 3 in kits are installed. Are you gonna put the leveling kit back on? I think they make a huge difference in appearance if you can make the step...
Old Aug 24, 2010 | 03:35 PM
redfire42's Avatar
redfire42
In his sig he has a single RW 250 where you have a DRW 350. Maybe I am missing something here. I just ran out and counted mine, I have 5 with the top one being the over load spring.
Old Aug 24, 2010 | 03:40 PM
X JBM X's Avatar
X JBM X
Looks Stock to me.
Old Aug 24, 2010 | 05:30 PM
Joelong258's Avatar
Joelong258
Well unfortunately he took it off and when he sold me the truck i got a bed full of spare parts and unless i missed it he never gave me the kit. I wish but ill be saving and hopefully doing a leveling kit or suspension lift in the future. The reason i asked is it seems fairly high off the ground to be stock and other f250s i see driving around sometimes look smaller.
Old Aug 24, 2010 | 09:01 PM
mikeyc0120's Avatar
mikeyc0120
The add a leaf is a single leaf and a block that goes on the top part of the spring. It doesn't affect the height of the truck, only when you have a load in the bed and it drops low enough to contact that leaf is when it comes into play. I had it on mine and had to take it off to put a bigger lift kit on it. It doesn't look like you have it on there.
Old Aug 25, 2010 | 10:03 AM
sideshow's Avatar
sideshow
I believe you are mistaking the factory overload springs. Usually an add a leaf is specifically for lifting the vehicle. A single leaf usually somewhere in the 2 inch lift range.
Old Aug 25, 2010 | 10:14 AM
mikeyc0120's Avatar
mikeyc0120
Ok I was going on what the company told me. When I called the lift kit company because I thought they sent me the wrong U-bolts for the axle, they asked if I had the add a leaf on top of the spring and told me I had to remove it. So I assumed that's what you were talking about. Sorry for the mistake!
Old Sep 16, 2010 | 02:01 PM
Spool&Go's Avatar
Spool&Go
I have a leveling kit. Can I also do a 2" add-a-leaf on top of that for more clearance?
mileswacker
Dec 15, 2016 04:59 PM
Stanstruck
1983 - 2012 Ranger & B-Series
Aug 20, 2014 02:46 PM
nlemerise
17
Jan 27, 2013 10:05 AM
Joelong258
Sep 18, 2012 06:19 AM
sdg0080
Apr 14, 2010 01:08 PM
