Hydro Boost Conversion
Old May 9, 2015 | 06:22 AM
hijo202's Avatar
hijo202
Mindfunk13...the York compressor is going to be pretty big if you were talking about putting it where the factory pump is/was. When I did mine, I remove the factory vac pump (it was toast) and also did the dual tensioner mod. I run an electric vac pump for the AC controls.
Old May 9, 2015 | 10:54 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
You may want to look at the sanden ac pump for a compressor. At one time riff raff had a kit with the sanden pump for the 99-03 superduties that mounted roughly where our vac pump is.
Old May 9, 2015 | 12:49 PM
mindfunk13's Avatar
mindfunk13
duel tensioner mod? link please?
i have the electric vac pump and just took the head off the belt drive one to use whats left, (pully and pressed bearing) as an idler)
Old May 10, 2015 | 03:06 AM
hijo202's Avatar
hijo202
I did the same (leaving pulley on) for a little until I found the correct length belt, now I run it without the pulley so one less bearing to wait to self destruct
Old May 10, 2015 | 03:08 AM
hijo202's Avatar
hijo202
Here's the link:
https://www.ford-trucks.com/forums/1...ne-w-pics.html
ford390gashog
278
Feb 5, 2021 10:13 AM
Pork_Chop50
Feb 6, 2017 10:05 PM
jtexfisher
Aug 1, 2016 06:51 PM
carguy29
Sep 30, 2015 04:05 AM
fordman400
Mar 13, 2013 01:07 PM
