Transmission slop
Old Aug 21, 2010 | 05:54 PM
jc8825's Avatar
jc8825
Transmission slop
I would like to tighten my shift lever. It engages gear nicely, it is just the handle that is a bit loose. I have checked the two bolts on the rear of the shift arm where it connects to the cable. They are tight. The plastic bushings are a bit worn (203K mi) but still okay. I don't see why that would cause this level of loose. Anything to do other than replace the shifting arm?
Old Aug 21, 2010 | 08:07 PM
Franko72's Avatar
Franko72
Molon Labe
Look at post #13 on this thread, it may help you out.
https://www.ford-trucks.com/forums/8...ng-column.html
Old Aug 21, 2010 | 10:16 PM
jc8825's Avatar
jc8825
Well, it's not on the transmission end. It is just in the lever mechanism on the top of the column. I would just like to tighten that if possible.
