Shifting issues
Old Aug 21, 2010 | 04:26 PM
Iceman_AKA_Ford guy's Avatar
Iceman_AKA_Ford guy
Shifting issues
Hey guys ive got a ?. My truck wants to stay in passing gear or 3rd gear alot. Ive read about passing gear linkage....where do i look for that? What else could cause it to want to bounce between 3rd and 4th gear?
Old Aug 22, 2010 | 08:55 AM
Iceman_AKA_Ford guy
over 40 views and no answers? wtf? guess i cant depend on info here.
Old Aug 22, 2010 | 09:30 AM
Slip ford man's Avatar
Slip ford man
I would start by checking the throttle valve cable for proper adjustment, freedom of movement etc...
Old Aug 22, 2010 | 10:26 AM
rla2005's Avatar
rla2005
It would help to list what transmission you have. Is it an AOD, E4OD or AOD-E (4R70W)? It makes a huge difference for what advice anyone can give you. If it is an E4OD or 4R70W there is no "passing gear linkage" to adjust. If it is an AOD, it uses a Throttle Valve cable. As noted in the previous response you need to verify it is properly adjusted.
Old Aug 22, 2010 | 08:02 PM
Iceman_AKA_Ford guy
how can i tell what trans. i have? its a 93 F150 5.0L my shifter in the cluster shows P R N OD 2 1
Old Aug 23, 2010 | 07:30 AM
rla2005's Avatar
rla2005
You may find these links helpful:
Ford Door Sticker Decoder .: Articles
Vehicle Door Jamb Sticker Decoding Page
Note down the numbers/letters on the door jamb sticker of your truck. Reference the decoders in the links above. Strangely enough I saw no transmission code for an AOD?
Old Aug 23, 2010 | 07:34 AM
Iceman_AKA_Ford guy
my door stickers are gone. they wasnt even there when i got the truck.
Old Aug 23, 2010 | 07:36 AM
Lazy K's Avatar
Lazy K
http://www.**************/myfiles/transmission.jpg Count the pan bolts and match here.
Old Aug 23, 2010 | 07:38 AM
Iceman_AKA_Ford guy
nvm the last post. i found the sticker. ive got a E4OD trans. so what do i look for to fix the issue?
Old Aug 23, 2010 | 08:17 AM
rla2005's Avatar
rla2005
Great info here: E4OD Diagnosis Thread
Old Aug 23, 2010 | 08:26 AM
carolinaranger90's Avatar
carolinaranger90
You need to chill, not everybody understands transmissions on here.
There's a lot of info and friendships to be had here on FTE, you just have to be patient on the help you receive if you get any seeing answering posts is not mandatory for us, I've been frustrated, but it happens, it's life, FTE is kind enough to be here at your disposal, but if some people don't have the answer, your not gonna see them posting, I've posted questions, and never gotten answers, It happens, expressing your frustrations like you did, i'm surprised anyone answered at all, it's not that they don't WANT to answer you, it's more like they may NOT know the proper answer, feel lucky someone didn't give you false information just to spark a word off.
The E4OD can be a picky transmission.
Check your fluid and make sure it's not discolored or "Burnt" smelling.
Simple things like that are known to thrown some transmissions off kilter.
Checking the fluid is ALWAYS my first move.
Also, see if maybe your shift sensor/Control module is operating correctly.
Just remember, we are ALL here to help each other, but not all of us have the correct answers to every single question asked.
Just Post, Relax and sooner or later you either get an answer or bump your question.
Old Aug 23, 2010 | 12:04 PM
Conanski's Avatar
Conanski
Your first order of business is to pull the codes, anything else is a complete waste of your time at this point since this transmission is computer controlled and many problesm can be traced back to a sensor or wiring issue. If that checks out perfectly clean then you will have to look elsewhere, given this a 5.0 truck if it turns out it also has excessively tall gearing then you may get a lot of transmission hunting at highway speeds particularly if you are in a hilly area. Again the axle code is on the drivers door pillar and 3.55's are about the minimum I'd want to see with this motor but Ford put as high as 3.08's in some trucks and that makes overdrive all but useless. If that's what you have then you can either change the axle gearing by swapping the ring and pinion or by swapping in another complete junkyard axle, or you can simply turn OD off and forget it's there.
Old Aug 23, 2010 | 01:44 PM
Iceman_AKA_Ford guy
looked it up. i got the 3.08 rear end. so until i can get the $$$ for a 3.55 guess ill just cut off OD. thanks for the info guys.
hotrodtodd
Jan 8, 2014 02:05 PM
f350rebel7788
Jan 6, 2011 10:42 PM
Lug-Nut
Jul 5, 2008 11:15 AM
backwoodspuller
Offroad & 4x4
27
Feb 5, 2006 10:17 AM
tranny guy
Jan 6, 2003 07:16 PM
