Finally! I get to drive...wait... another problem
Old Aug 21, 2010 | 03:36 PM
Wicked Endings's Avatar
Wicked Endings
Hey guys! If you have been following my past threads, I have been without a truck for about a week.
It all started with me wanting to change my brake caliper on the passenger side. Then, I found that I needed to change the bearings in the hub. After cutting the hub/rotor assembly off of the spindle with an angle grinder, the bearings were welded to the spindle, making the spindle trashed...
So, I went and bought a knuckle/spindle assembly and I was going to put it on today until I found that the old camber sleeve (at least I think that's what it is) is still in the knuckle/spindle assembly I bought.
So, here are a few pictures...
Spindle with bearings welded on...
New Knuckle Spindle Assembly with Camber Sleeve
So, this is my question...
How do I get the camber sleeve out of the new Knuckle/Spindle assembly without harming the knuckle/spindle assembly?
Old Aug 21, 2010 | 04:06 PM
bashby's Avatar
bashby
just tap it out with a hammer. When you reassemble, thghten the lower BJ up then install the camber bushing and tighten the nut on the upper (I guess it would be best to use the old one indexed like it was)
Old Aug 21, 2010 | 04:55 PM
Fordzilla80's Avatar
Fordzilla80
If you can't get it out with minimal effort,spray a little WD 40 or similar around it and see if that helps.
Old Aug 21, 2010 | 07:48 PM
Wicked Endings
Well, I took a sledge hammer to it. Two hits and it came out. No big deal.
YAY!
Old Aug 22, 2010 | 09:23 AM
85_Blue's Avatar
85_Blue
That piece looks scary! I hope you got alot of elbow grease to clean it up before you install it!!
Wicked Endings
Projects
May 7, 2025 02:21 PM
Wicked Endings
Dec 27, 2010 11:54 AM
Wicked Endings
General Automotive Discussion
28
Dec 27, 2010 02:19 AM
Wicked Endings
Aug 22, 2010 06:23 AM
Wicked Endings
Projects
Jul 30, 2010 11:24 PM
