Modular V10 (6.8l)
v10 engine misses
Old Aug 21, 2010 | 12:31 PM
YoVinni's Avatar
YoVinni
v10 engine misses
Took v10 to (limited) auto shop, they performed a diagnostic on it, determined that coils going bad on certain cylinders.
replaced all 10 coils and plugs with Motocraft parts........
Runs some better but still has miss....mostly under load.
Took back to shop, performed scan test again, determined #4 causing problems now. Switched out coil and checked plug for defect. No change.
Pulled vacum leak test and was good.
Mechanic now baffled, says might be injector or backed up cat causing this. Initial test indicated was ignition, would injector cause ignition code?
I didn't think a cat could cause this.
Any ideas?
Anyone have a good fuel injector cm4809 F6VE-A5A laying around that you might consider parting with for a bit so I can test this out? I will send back and reimburse postage.
Old Aug 21, 2010 | 02:10 PM
Mr-Pipeline's Avatar
Mr-Pipeline
What year is your truck? Might have the mechanic swap injectors and see if the problem follows? I have a set of injectors out of a 2006 2v V10 not sure if they are the same? My understanding is all 2v 10 injectors are the same. Maybe some of the other guys will chime in shortly. Welcome to FTE, glad you found us.
Old Aug 22, 2010 | 11:16 AM
YoVinni's Avatar
YoVinni
Thanks for the reply, it's a 1999 F350. I'll do some checking also. I do know that there are basically two types of injectors...ones with round to oval connection point and one with rectangular connection point, mine is the latter.
Old Aug 22, 2010 | 11:37 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
An injector can cause a single misfire code on one cylinder, that's for sure.
Old Aug 22, 2010 | 03:14 PM
Mr-Pipeline
YoVinni,
Here's a picture of the injectors. The orange ones came out of my 2000 F350 and the green/blue came out of a 2006 E350. I put the orange injectors back into my truck and have the green/blue set collecting dust. This should be the same...? Let me know.
Old Aug 22, 2010 | 06:14 PM
YoVinni's Avatar
YoVinni
Originally Posted by Mr-Pipeline
YoVinni,
Thanks for all the work Mr-Pipeline but those aren't the same as mine, my connectors won't hook up to those. Mine have the rectangular connection point. I do appreciate it though. Hopefully someone has one like mine. Thanks, Vince
Old Aug 31, 2010 | 08:59 PM
YoVinni's Avatar
YoVinni
Well, I'm puzzled...I got the new injecor installed on # 4 and still misses.......Anyone got any ideas for me?
Old Sep 1, 2010 | 06:01 AM
krewat's Avatar
krewat
Do a compression check. Especially on that missing cylinder. Something's up with it.
Old Sep 1, 2010 | 04:31 PM
YoVinni's Avatar
YoVinni
Thanks, I'll check it out.
TeamMudd
Modular V10 (6.8l)
Jun 3, 2017 04:54 PM
jerryjerry05
Modular V10 (6.8l)
Oct 31, 2014 07:11 AM
Electricredmetallic
Mar 15, 2014 10:55 AM
ggalleone
Modular V10 (6.8l)
Jun 12, 2011 04:52 PM
Bear River
Aerostar
62
Mar 21, 2008 02:36 PM
