1966 - 1977 Early Broncos
Bump steer with power steering
Old Feb 16, 2003 | 12:14 PM
Mike W's Avatar
Mike W
Installed a F-150 power steering box on a 72. The manual box had no signs of bump steer The power steering does. Lift is maybe 2". The steering linkage has a very slight angle up to the pitman arm. Anyone got any ideas as to what is causing this?
Old Feb 16, 2003 | 03:49 PM
RCrawler's Avatar
RCrawler
Installing the F150 box caused it...
It's very common for this to happen with the 2wd box conversion. The main problem is the long pitman shaft used in that box changes the angle of the draglink in relation to the angle of the track bar.
You want the draglink and the track bar to run as parallel to each other as possible.
Do you have any steering correction for the lift kit? Pitman arm, drop track bar bracket, adjust. track bar?
This is the main reason why most of the Bronco specialty companies have gone away from the F150 conversion.
Jason
Old Feb 16, 2003 | 07:00 PM
Mike W's Avatar
Mike W
Hi Jason, I just checked the angles. The draglink to the pitman arm is 2 1/2 degrees. The track bar is 10. Another Bronco that does not have the bump steer measures 10 and 12 degrees, has a Toyota box. If I put a drop bracket for the track bar on so I can match the angle, do you think it will correct it? Thanks
Old Feb 16, 2003 | 09:25 PM
RCrawler's Avatar
RCrawler
So the draglink is almost flat compared to the tie rod?
The drop track bar bracket should help some of it. It will drop the track bar down about 3.5" from stock.
What pitman arm are you using on the F150 box?
I have a stock 77 box on mine with a drop pitman arm. With roughly a 2.5" lift, the bottom of the pitman arm measures about 5.25" from the bottom of the frame. I have a track bar bracket and this makes the draglink and track bar just about where they need to be. I can't remember how far the F150 box hangs down, but that should give you a ballpark to shoot for.
There is a steering box that shares the bolt mounting pattern with the F series box but has a short pitman shaft. Mid 60's Lincoln Continentals used a 3 turn box that matches the F150 box. The pickup steering box puts a lot of stress on the frame because of the extra leverage from the long pitman shaft. It isn't a very popular swap because they are getting hard to find.
Jason
Old Feb 16, 2003 | 10:43 PM
Mike W's Avatar
Mike W
I am using the pitman arm off the old manual box. It is almost straight. Does the drop track bracket bolt on or do you weld it on?
Old Feb 17, 2003 | 08:53 AM
RCrawler's Avatar
RCrawler
All of the brackets that I have seen are bolt on. They can be bolted on and welded to keep them in place.
Jason
uberkarldrei
Sep 11, 2007 01:09 PM
gusso
26
Aug 20, 2007 06:57 AM
moonley
24
Apr 8, 2005 12:35 PM
bjoern
Aug 9, 2001 01:20 AM
blaxuede
Apr 24, 2001 07:12 PM
