solid lifter valve adjustmen question
Old Aug 21, 2010 | 09:17 AM
hiball3985's Avatar
hiball3985
I have a question and need some opinions.
First the facts:
1966 F250 4speed
390 cu inch
427 factory cam
This is NOT a race truck. Its an everyday work horse.
I have always adjusted the valves to the factory 427 setting .025. Needles to say this is some what noisy in the cab when driving at high rpm
Questions: Does any one know what was the purpose of these settings? Was it just for race purpose?
Has anyone ever tried running a tighter setting for a street engine?
Need opinions: All and any
Thanks Jim
Old Aug 21, 2010 | 09:35 AM
mikeo0o0o0's Avatar
mikeo0o0o0
The clearance is to allow for expansion when things get warmed up. If the clearance was "0" then the valves would be held open a slight amount when the engine warms up and wouldn't seal.
The clearance is determined by the design of the cam's clearance ramps, hydraulic cams don't utilize the ramps thats why they tap so bad when just a little clearance exists when the lifter goes bad.
The clearance ramp is that area of the lobe that transitions from no lift to lift. It "gently" takes up the clearance and starts to open the valve.
Closing up the clearance is an old tuners trick, done all the time to fine tune the engine to a particular track or weather conditions.
Closing up the clearance increases both the lift and durration slightly so in a sense you are making the cam a little more "radical".
I would say closing the clearance up to maybe 0.015" to 0.017" would be okay depending on how close you're running your piston/valve clearance.
I would start at maybe 0.020".
Are you setting the valves hot or cold? and what kind of shape are your rocker arms in? If the valve contact area of the rocker arm is worn this will throw off your feeler gauge setting and there will be more clearance than indicated. Rocker arms can be refinished on a valve machine.
Old Aug 21, 2010 | 10:05 AM
hiball3985's Avatar
hiball3985
Mike,
Thanks for your input and info. The rockers tips are in excellent condition. I always adjust them hot. My thought was starting at .021. I don't think I would risk anything tighter. Heat isn't a concern either, it never runs over 180-190 unlike a race engine.
So I'll give it a try
Thank you
Jim
Old Aug 21, 2010 | 11:08 PM
Moto Mel's Avatar
Moto Mel
The early Ford performance engines with solids had a specification of .020 clearance so it would be okay to run that tight with no problem and it was used often by racers in fine tuning an engine to a specific track or condition.
Old Aug 21, 2010 | 11:26 PM
hiball3985's Avatar
hiball3985
Thanks for that additional info. I had never seen a .020 clearance specified anywhere. And I've been working on them since 1964. SO I should be good.
Jim
Mister_King
Jan 26, 2015 05:32 PM
Bullitt390
Nov 16, 2014 11:21 PM
JDBeck23
27
Sep 21, 2012 12:49 PM
Jontremblay
23
Sep 29, 2010 05:06 PM
ilikefordtrucks
Sep 15, 2004 04:23 PM
