Running gear swap
Old Aug 21, 2010 | 04:03 AM
19871978ford's Avatar
19871978ford
Running gear swap
How hard would it be to swap f250 running gear into a f150 shortbox. Is it worth the hassel. I want a locker in the rear.
Old Aug 21, 2010 | 11:09 PM
85e150's Avatar
85e150
Whatever axle your F150 has, a locker can be had for it.
What axle do you have?
Swapping in the F250 stuff would be the loooong way around.
Old Aug 22, 2010 | 05:54 AM
19871978ford
I think its a 9inch but i will have to double check. So the heavier stuff really wont make that much difference
Old Aug 22, 2010 | 05:52 PM
85e150's Avatar
85e150
A difference in what? Traction? Not really, that's more tires and the locker. Many flavors of locker available for the 9". Last year for the 9er was '85 or '86 iirc. Just as many available for the 8.8" also.
Gotta budget? They are not free:
Currie Enterprises Racing Rear End Categories
Detroit Truetrac looks like a winner, others here have reported good luck.
Old Aug 22, 2010 | 10:04 PM
19871978ford
I mean strength. Im going to be running 38's.
Old Aug 23, 2010 | 12:09 AM
85e150's Avatar
85e150
Well, this propaganda piece says up to 38s with a 9er...
Ford 9 Inch Axle - Four Wheeler Magazine
Depends on how you're going to run it. If you are running hard and jumping, you probably ought to go up to a beefed heavier axle.
But if you have stock suspension, you're going to break stuff doing that even with the heavier axle....
HAVEaSigAR
15
Jul 24, 2014 05:12 AM
Trey430
Mar 29, 2012 09:35 PM
old'skewl
Dec 13, 2011 07:44 PM
J Hodges
Jul 14, 2007 04:08 PM
wolfe1104
Mar 4, 2006 10:58 PM
