missing
Old Aug 20, 2010 | 10:14 PM
milleroutdoors's Avatar
milleroutdoors
missing
Hi guys I hang out mostly in the 7.3 forum, my son's friend has a 6.0, it is missing at an idle and in some of the throttle positions it misses. It runs ok part of the time. Dealer said #4 injector is bad. I have an ae and will scan tomorrow. Any ideas where to concentrate? I am a little leery of the dealer's prognosis. I might add there is no smoke and no other obvious symptoms.
Old Aug 21, 2010 | 07:14 AM
Maxium4x4's Avatar
Maxium4x4
The dealer could be right if they ran a contribution test on the injectors. What year is the truck? Another area to check is the ICP to see if it is leaking oil.
Old Aug 21, 2010 | 08:17 AM
bismic's Avatar
bismic
What oil is he using (and what brand of filter)?
An injector issue could be stiction - that sometimes can be "remedied" by the proper oil and a flash update to the processors. Some folks say Rev-X has helped also.
It is always worth verifying that the batteries are healthy and the FICM voltage is good (but if it is only one injector code, these components are probably not the issue).
Knowing the code(s) would be a help.
Old Aug 21, 2010 | 08:31 AM
cheezit's Avatar
cheezit
https://www.ford-trucks.com/forums/974064-my-ride.html
theres a picture in this thread of what the contribution looks like. as well as a very random cyclinder misfire.
Old Aug 22, 2010 | 10:11 AM
milleroutdoors
Well it failed the contribution test as well as the buzz. Will swap out #4 and go from there. Thanks for the input.
Old Aug 27, 2010 | 10:23 PM
milleroutdoors
We swapped #4 injector and still the same failure. Checking wiring. Any other suggestions?
