93 351W Issues
Old Aug 20, 2010 | 09:32 PM
bigblu78's Avatar
bigblu78
93 351W Issues
Hello to all first off. I have been around the IDI forum for quite some time now but I have recently picked up a new farm truck thats a gasser so I have come to you all for some advice. The truck is a 93 F-250 4x4 with a C-6. The problem is that the truck has a bad miss on the driver side bank of the engine. I have pulled the plug wires while running and the center two cylinders appear to be not firing all the time. The truck idles just fine but under a load it gets a miss with a "popping/ticking" sound almost like an exhaust leak. I have been unable to locate my compression tester for some odd reason so I have not tested that. I did however hold a dollar bill up to the exhaust while the truck was running and everytime I heard the miss the dollar would get sucked into the pipe. Correct me if I am wrong but that indicates a burnt or stuck valve right?? If so... how should I go about correcting this issue. BTW... Please forgive my ignorance. I have been working on diesels for too long. I believe I have forgotten too much about gassers!!!
Thanks in advance for your input.
Old Aug 21, 2010 | 08:08 AM
17Z's Avatar
17Z
Almost sounds like a head gasket blown out on the left bank between the two bogus cylinders.
OldWoodsDiesel
19
Nov 14, 2012 09:10 AM
mtnsammy
Jul 31, 2012 02:53 PM
akamacgyver
Nov 12, 2011 01:11 PM
powerstoked!
Dec 27, 2010 03:05 PM
ccg711
Oct 21, 2008 05:42 PM
