Engine dies when headlights are turned on??
Old Aug 20, 2010 | 10:18 PM
milleroutdoors's Avatar
milleroutdoors
Originally Posted by Izzy351
I had the same issue. Grounding the ballasts greatly reduced the problem.
Joe do you remember the thread on this? I think Kupaa had a similar issue.
Old Aug 21, 2010 | 01:30 AM
kupaa's Avatar
kupaa
Like Joe said,make sure the ballast is grounded good(i actually made a ground wire from the ballast to the frame).Next is you have to take the relay,if you have one from the driver side battery to the passenger side battery.The PCM use the power from the driver side battery and when the lights turn on it drops the voltage enough to stall the engine.Hope this helps you it did for me.
superduty4x4
44
Jan 13, 2011 02:28 PM
cbrnflt
Jan 4, 2008 08:12 AM
