Sponsored by: Real Truck
QUESTION ON FRONT BRAKES TO CORRECT PROBLEM...
Old Aug 20, 2010 | 05:28 PM
edster's Avatar
edster
Question QUESTION ON FRONT BRAKES TO CORRECT PROBLEM...
My outer front pads wore out in under 10,000 miles, but inner pads like new. Calipers seem to move in and out ok. I am changing the hardware clips, cleaning all parts with brake cleaner and putting brake grease on caliper bolts. Should this take care of issue??? Any other suggestions... One rotor was thrashed replacing and turning the other..... Thanks
Old Aug 21, 2010 | 09:39 PM
ZBIGBIG19TH's Avatar
ZBIGBIG19TH
Did you grease slide pins? you did grease bolts?
daveplot
Aug 21, 2015 05:46 AM
Harpo2013
6.7L Power Stroke Diesel
22
Jun 16, 2014 08:55 PM
spray004
1997 - 2003 F150
Dec 4, 2010 04:06 PM
Jim Hughes
Jan 28, 2007 07:37 PM
spycam
Aug 11, 2004 01:20 PM
