Sponsored by: Kumho
Broken lug!
Old Feb 16, 2003 | 10:08 AM
motobub's Avatar
motobub
Broken lug!
I just bought a 1991 f250 deisel. One of the lugs is broken off. Should I change it or wait untill I'm doing something else with the brakes or something? There are 7 others, do you think I need to change it right away?
Thanks
Lars
Old Feb 16, 2003 | 04:30 PM
wille3r's Avatar
wille3r
Broken lug!
I wouldn`t worry about it until the next time you have to take the wheel off. I`ve got a few missing on mine too! UNLESS, you pull heavy loads all the time.
Old Feb 17, 2003 | 06:05 PM
rebocardo's Avatar
rebocardo
Broken lug!
In an ideal world, do it right away. In the real world, if it is on the rear and you do not carry very heavy loads, I would not worry about it until the next brake job.
If it is on the front, I would replace it as soon as possible, especially if you drive at high speeds (80-90 mph).
The longer it goes unreplaced, the more likely other studs will break. I think most break because
1) people do not clean the threads before taking the nut off with a strong impact gun
2) they over torque them.
It is a $2 part. The cost of replacing something in the front if the wheel comes off while you are moving at just 15 mph will greatly exceed the cost of a $2 stud and the labor to replace it.
E.j. May
Nov 1, 2021 11:58 AM
f-250diesel
20
May 6, 2011 09:14 PM
BradyCouchman
Jul 16, 2010 08:19 PM
mattjensen
Apr 24, 2009 04:28 PM
frachubb
Bronco II
Oct 16, 2003 03:14 PM
