Sponsored by: Kumho
Rim leaks
Old Aug 20, 2010 | 11:45 AM
john fin's Avatar
john fin
Rim leaks
I have been having rims leaks and noticed that they are coming from these factory dimples. What are these for?
Old Aug 20, 2010 | 12:05 PM
hcbph's Avatar
hcbph
Dimples
Just a guess on my part but I'd guess it has something to do with mfg or machining the rims. Some piece of equipment probably uses that to lock part of the rim down while some other assembly or machining process happens. With 2 of them facing each other, it wouldn't be too hard to have 2 claws lock into them.
Just a guess.
By the way, how did you determine that is the cause of your leak? Had a persistent leak on a 79 Olds I bought new. Several times it went in and one tire still leaked. Finally replaced the rim and the problem was gone. The mechanic was persistent, he put a junk tire on it and sank it in water. Every once in a while a bubble came off (actually out of) the rim. Turned out the rim was porous and that was the cause of the leak.
Old Aug 20, 2010 | 12:14 PM
john fin's Avatar
john fin
Rim
I marked the rim and tire where the bubbles were. pretty constant stream of bubbles.
Old Aug 20, 2010 | 12:36 PM
hcbph's Avatar
hcbph
Leak
Not doubting you there, but could it be the bead on the tire that has the problem and not the rim? From the looks, I'd think the tire bead should cover that fairly well. I'm guessing you're not the only person with those indentations in the rim and can't say I've heard of others complaining. Here's a thought, rotate the tire on the rim say 90 degrees and see if the bubbles stay in the same place or not. If they don't move, maybe fill them with something like J-B Weld, sand it down then mount your tire.
Old Aug 22, 2010 | 12:14 PM
bashby's Avatar
bashby
A little dab of permatex rtv should seal it up
irydhd
1997 - 2003 F150
May 15, 2013 08:11 PM
redbug
Jun 19, 2010 09:50 AM
cstevens00
Jul 21, 2007 09:29 AM
F250_HD_Crew
Jun 16, 2005 08:58 AM
Quadiquizm
Aug 10, 2002 01:17 PM
