Significant Oil Consumption
Old Aug 20, 2010 | 08:18 AM
80FlareSide's Avatar
80FlareSide
Im having trouble with my 1980 302 motor with either 21k, 121k 0r 221k (95% sure is 121k. Its comsuming a good deal of oil, and Im not sure where. One clue is that im also getting alot of combustion blow-by, to the point that there sputtering out of the dipstick tube.
What is wrong? Rings? Valve guides? Valve seats? Something else entirely?
Old Aug 20, 2010 | 09:38 AM
Grubbworm's Avatar
Grubbworm
What is "a good deal of oil"? IIRC, one quart per 3000 miles is acceptable.
Old Aug 20, 2010 | 09:52 AM
80FlareSide
Im probably loosing a quart to every 500 miles. Im sure the leak in my booster isnt helping with the sputtering out of the dipstick tube, but I cant imagine its connected to this problem.
Old Aug 20, 2010 | 11:21 AM
Lightningjr's Avatar
Lightningjr
Does the motor smoke at all? Are you leaking oil some where other than the dipstick tube? If you are getting the blow by you say you are then yes it can cause it to come out the dip stick tube but the motor would run like crap. Thats alot of blow by...
You should do a leak down test and find out where exactly you need to start working. BUT since these motors are easy and cheap I would just rebuild it anyway.
punkrockpilot
20
Jan 22, 2011 09:11 AM
otpracer100
Feb 26, 2007 07:32 PM
Steven@nd
1997 - 2003 F150
Apr 23, 2006 09:11 PM
aaronsxs
1983 - 2012 Ranger & B-Series
21
Dec 7, 2003 07:30 PM
WrenchHead84
Jan 27, 2002 07:07 PM
