Simple Question
Old Aug 20, 2010 | 12:06 AM
StSt's Avatar
StSt
Simple Question
I have a 94 ext cab with 4.9 auto.
OK, If when I park my truck when I get home, open my hood and am able to freely spin my radiator fan, is my fan clutch bad?
I’m Suspecting it’s bad because at stop lights in hot weather the engine temp starts to go up.
Thanks,
Old Aug 20, 2010 | 12:45 AM
f-150_1993's Avatar
f-150_1993
no. its normal.
you probably have a bad thermostat
or maybe it needs more coolant.
cooling system can also be clogged.
Old Aug 20, 2010 | 04:04 AM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/8...ml#post7461511 Here is the way to test your fan clutch.
Old Aug 20, 2010 | 04:24 AM
lew52's Avatar
lew52
Thats the sign of a bad fan clutch . When the motors warm there should be some drag on the fan clutch , do the test , if it spins with no drag then replace the clutch , ....Lew
Old Aug 20, 2010 | 07:25 AM
Encho's Avatar
Encho
The Southernmost Mod
The fan clutch should turn freely, at least not with ease, it has to oppose some resistance, yet still turn. If it doesn't oppose any resistance, it's gone.
