Vacuum line
Old Feb 16, 2003 | 08:51 AM
quadman's Avatar
quadman
Angry Vacuum line
Whoever had my truck before unhooked and plugged a vac line it is tan in color and goes behind engine to a brass canister which appears to be hooked in to heater hose. What is this and what does it do? Should I be concerned as I hooked it back up and don't notice any difference in truck performance.
1993 F-150 4x4 S/C S/B 5.8l
Old Feb 16, 2003 | 12:57 PM
steve83's Avatar
steve83
Vacuum line
Sounds like it goes to the air diverter valve for the smog pump plumbing into the catalytic converter (thermactor air system). It's actually yellow. You should have a vacuum map on the hood over the air cleaner that shows it and gives abbreviations. You can see one that should match yours here.
