EGR valve baffle?
Old Aug 19, 2010 | 11:05 PM
danocross's Avatar
danocross
EGR valve baffle?
Anybody heard of a Ford aftermarket item that enhances the function of the EGR valve? A baffle of some sort? That is all I know, rumor stuff, apologies up front if this sounds stupid...any help is appreciated.
Old Aug 20, 2010 | 02:23 PM
danocross's Avatar
danocross
Finished my 100k service, Ford checked FICM voltage (47.5), fuel pressure (58) and cleaned EGR valve, which looked good. The baffle plate I referenced above is part number 6C3Z-9P449-A. Just curious what the techs on here or others know about this. The service advisor told me the techs like it, he says it helps keep the EGR functional and clean of carbons, but I have not heard about it on here, or otherwise.
Thanks for anyone with more info on the whole baffle plate deal.
Old Aug 20, 2010 | 02:42 PM
nylyon's Avatar
nylyon
There's a TSB on this item 08-26-12.
Old Aug 20, 2010 | 03:03 PM
bpounds's Avatar
bpounds
Wow, that TSB is interesting reading.
Those guys that like to refill your crankcase with the whole 15 quarts should read it.
Anyone got a picture of the baffle, part 6C3Z-9P449-A?
Old Aug 20, 2010 | 03:21 PM
Heckler's Avatar
Heckler
How much do you put in? I was told 14.5 is that too much?
Old Aug 20, 2010 | 03:25 PM
danocross's Avatar
danocross
My only concern is that I have not had any EGR issues, and they put this in. I don't think it was to chalk up another sale, I asked them to pull the EGR valve while they checked the FICM voltage and the fuel pressure. They said the valve looked good, the passages look good, and here is an extra measure of protection for you while we are in there.
Old Aug 20, 2010 | 03:29 PM
bpounds's Avatar
bpounds
The TSB implies that higher oil levels will increase the amount of oil that the CCV will pull. That makes some sense particularly if there is any foaming going on. It says to suggest to the customer to keep the oil level at the middle of the dipstick. That's what I do, but I do it for a different reason. This is the first time that I have seen a Ford document suggest that.
Filling with 14 quarts does that for me. Now I have another reason for doing it my way.
Old Aug 20, 2010 | 03:33 PM
nylyon's Avatar
nylyon
The part should cost less than $10, and the labor should be next to nothing if the EGR valve is already out. I doubt that the dealer is making much on this at all, so they must really believe in it. I did not buy this part, but it was recommended to me by 2 tech's, so there must be something to it.
Old Aug 20, 2010 | 03:41 PM
danocross's Avatar
danocross
Karl, I am with you 100%. The tech here has been real good. But I thought it would not hurt to raise the issue on here, maybe pass along a good idea that I have not heard of before.
Old Aug 20, 2010 | 03:43 PM
Heckler's Avatar
Heckler
I'll have to try 14 next time, even though I can barely even read that damn dipstick!
Old Aug 20, 2010 | 03:46 PM
bpounds's Avatar
bpounds
I hope a tech will drop in and give us an opinion on this thing. Meanwhile, here is mine.
Read the TSB. It is really informative. As I read it, the baffle is a bandaide action for some other issue. The problem is excessive oil in the intake air flow. The TSB is clear that the tech should try to diagnose and cure the issue which is causing the excess oil.
The baffle goes below the intake elbow, not in the EGR port and not on the valve. It's purpose is to keep the oily intake air from flowing directly across the EGR valve and causing it to get sticky, thereby collecting more soot and clogging the valve.
If your EGR valves are coming out sticky with oily soot, the baffle might help keep the valve dry, but it won't solve the question of where the oil is coming from. If you have such an issue, a CCV reroute might be much more effective. But of course Ford cannot sell us that.
Old Aug 20, 2010 | 05:37 PM
cheezit's Avatar
cheezit
this tsb is outdated and no longer used. sorry..
its a great sorce of information on the many things that will create the po401,p0404,
p1335 ,p0299 dtc's
Ive installed the baffle maybe 2x. not something I see much use to. I would rather know I had an issue and get it fixed vs. tring to cover it up long enugh to make it go away.
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Jan 16, 2017 05:04 PM
Thom12
6.7L Power Stroke Diesel
Oct 28, 2016 04:57 AM
1973supercamper
Apr 28, 2016 08:38 PM
dcolby10
Mar 28, 2016 08:48 PM
bhalemail
WTB - Parts & other
Feb 2, 2016 02:22 PM
