busted frame
Old Aug 19, 2010 | 09:13 PM
bazzman1953's Avatar
bazzman1953
busted frame
I have a '90 F-150 beater that I picked up cheap. It was used as a plow truck and has a busted frame on the right front side right where the r/f brake line goes through the frame. Keep it or junk it is my problem. Lots of new parts on it and I'm going to need a 4x4 truck come winter. Any idea what the cost of repair will be? I discovered it had busted when I had a sudden brake failure due to the r/f brake line shearing, fortunately on a back road so I could coax it back home.
So keep it or junk it???
Old Aug 19, 2010 | 09:38 PM
17Z's Avatar
17Z
Could likely find yourself a decent welder dude to plate her back up...good to go.
I had an old decrepit Dodge short/wide....and it's frame busted off in front of the steering gear box. Not to mention the frame was cracked up bad underneath the steering gear.
I used a section of Dodge frame off a scrapped truck and plated/welded it on in front of the suspension. Got rid of all the cracks with a section of old frame. Probably not an 'approved' repair....but otherwise the machine was junkyard fodder.
I would think that if the frame's broken area was where it could be reached fairly easy, a good welder could fix it in a jiffy.
Old Aug 19, 2010 | 09:44 PM
hillbilly469's Avatar
hillbilly469
Personally I'd fix it if it were mine. But then I have a welder and can weld so it would only cost me a few bucks to fix it. I would check with your local laws as to whether it would be legal to do so, some states won't allow such repairs. The cost of your fix depends greatly on where it cracked do to the numerous items that may have to be taken of to make the repair. Any competent welder should be able to repair it but you may end up with a farm truck not a highway truck due to local inspection laws. I'd definitely check those out before putting money into a repair.
Old Aug 19, 2010 | 09:54 PM
leavy20's Avatar
leavy20
i would keep it, maybe weld as a temp fix and look for a new frame. get the new frame and clean it up, beef it up, and your at the beginning of a resto.
Old Aug 20, 2010 | 10:30 AM
JMC302's Avatar
JMC302
I would get it fixed to get you through the winter, then look for a truck that needs a drive line and use your current rig as the parts truck.
Old Aug 20, 2010 | 11:54 AM
Onus's Avatar
Onus
Sounds like my truck. I picked up a 91 f250 with plow. Was cheap. The frame is rusted in one spot and everything else looks solid frame wise munis rust scale. I'm checking with the welding place across the street next friday and have it welded up. Then i'm getting all the scale of and coating it with kbs coating which is like por-15 so i know it's solid for time to come.
Old Aug 20, 2010 | 12:52 PM
nstueve's Avatar
nstueve
I'd pick up a cheap stick welder from www.craigslist.org and repair it yourself 9if you don't already own a welder that is)... that way the $$$ you spend to have someone else fix it will be in a new tool for the garage! Just go and get some 1/8 or plate steel from a steel yard, cut it to fit past the cracks 2-3inches and weld it in... If the crack is spread apart terrible use some plug welds on one side and weld the outer edge of the plate steel into one side of the frame. then use a 2 ton floor jack to lift the trucks front end to close the frame gap and weld the other side of the steel plate...
Have fun!
Old Aug 20, 2010 | 01:04 PM
Brain's 97 Diesel's Avatar
Brain's 97 Diesel
First what are your abilities to do this repair. Second what friends do you have that can do this repair. Third what are the DMV laws/codes for safety/inspection in your area. Fourth what will it cost you to hire someone to do the job. In that order answer thes questions. If you or your friend can repair and keep quiet so be it, but if you have to pay someone then what are the "legal" options.
I'd fix it and keep my eye out for another "parts" truck or frame.
Old Aug 20, 2010 | 01:56 PM
Slip ford man's Avatar
Slip ford man
I would repair and keep it for the winter, then junk it in the spring. I have a welder machine , but you also could sandwich the break with some 1/4 steel channel stock, drill and bolt using a dozen 1/2" bolts. I would give her a larger over lap, say 12 inches or better, each side of the break if possible.
Old Aug 21, 2010 | 12:36 AM
Onus's Avatar
Onus
I would agree go temporary now and find a replacement frame at some point. Cracking doesn't sound very fun. Your whole truck will rest on that weld / joint.
Old Aug 22, 2010 | 12:44 PM
Brain's 97 Diesel
Another thing you should do is drill a hole 1/8" to 3/16" at the end of each crack. This should help strop the crack from traveling further prior to welding it up. You could plate it like others suggest w/ plug welds, just make sure the plate doesn't have sharp edges or corners. I'd weld the ends solid w/ a series of shorter stich welds.
Old Aug 24, 2010 | 10:05 AM
nstueve's Avatar
nstueve
just keep in mind that after plating and using stich and plug welds your frame will actually be stronger than anywhere else on the truck. You can also plate the area as well as "boxing" the fram at that point... Boxing is where you make a full rectangle out of the frame so it doesn't have an open side.
95f2504x4
15
May 4, 2012 11:57 PM
acoers
2004 - 2008 F150
18
Feb 5, 2010 07:01 PM
L.TONY F350
Dec 23, 2009 08:53 PM
mizzitch
Oct 23, 2007 12:25 PM
hreed
General Automotive Discussion
16
Jan 28, 2004 10:33 PM
