AC Heater Blower
Old Aug 19, 2010 | 03:25 PM
DadNSonF350's Avatar
DadNSonF350
AC Heater Blower
My 1994 F-250 5.8 Auto is having trouble with the AC Heater blower. It blows but very little. Before I go throw down good money for a new blower motor is there anything else I should check first?
Old Aug 19, 2010 | 04:16 PM
96ford250's Avatar
96ford250
ground and if its getting enough power to it also check to make sure nothings crammed in it
Old Aug 19, 2010 | 09:55 PM
17Z's Avatar
17Z
My recently purchased 95 F250 had similiar issues when i got it a couple weeks ago.
The AC was cold, and the blower motor sounded ok, but just not enough air flow from the vents.
A customer of mine clued me in that you can remove the blower motor, and access the evaporater core to clean it out.
I removed the motor, and had a rats nest sucked up against the evap. core! Consisted of some sort of fibreglass insulation(I don't think it was off the truck...rat imported insulation), and wheat...yes, wheat. I cleaned that crap out, and blew out the evap core as good as possible with a air nozzle made of long copper pipe( so you can bend it around corners). This fixed the feeble air-flow issues.
I also took the opportunity to repair the vacume line to the recirculating air dash-pot since I was working right there.
Was really an easy enough task...handeled with a 1/4" socket set, air compressor, and blow nozzle. Took maybe 30-40 minutes. Also turned a so-so air con system into a really cold sucker...without messing with freon charge.
