3rd brake light on '96 Explorer...
Old Aug 19, 2010 | 12:25 PM
dan8052's Avatar
dan8052
How do you replace the bulb?
Old Aug 19, 2010 | 02:34 PM
87 XLT's Avatar
87 XLT
If this is wired the same as my 97, it will have a seperate fuse for the third brake light. I'd check that b4 doing anything else.
Old Sep 12, 2010 | 08:40 PM
bigjmcconnell's Avatar
bigjmcconnell
Did you get it working? I've had a few explorers from that era. Some of them actually have a ballast separate from the light that can go bad. I still have a good one here if you find out thats what you need.
Old Sep 16, 2010 | 10:58 AM
dan8052's Avatar
dan8052
The fuse is fine. Where might I find the ballast?
Old Sep 28, 2010 | 06:06 PM
supersuperduty's Avatar
supersuperduty
remove the rear hatch inner door pane.l right behind where bulb would be is transformer i got a new one from salvage yard for 5 bucks all set 99 percent of the time its the transformer not the bulb assembly
Old Mar 22, 2011 | 09:19 PM
96explorer96's Avatar
96explorer96
It turns out that I need a ballast for my 96 EB Explorer. Still have one?
Old Mar 23, 2011 | 07:07 AM
bigjmcconnell
I can't remember if I sold it or not. I'll did into my explorer parts and see.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
