driveline tips anyone?
Old Aug 19, 2010 | 02:29 AM
Snobord28's Avatar
Snobord28
HI all im rebuilding a 1951 f-1, and after the swap of engine/trans and rear end, I need a driveline. I think i measured about 61 in from rear end yoke to inside trans shaft . I was thinking of having one made but im broke as it is and wanna get running soon, what are you all using? whats a good donor vehicle to look for at the junk yard? Thanks
Old Aug 19, 2010 | 03:13 AM
55 f350's Avatar
55 f350
i'd say your gonna have to have a shaft cut no matter what , the only way around it is to find a running flathead 6 or v8 and tranny like was in it and the odds of getting one that doesn't need something is not going to be in your favor . so ..... with that said , go look for a late model 5.0/302 or 351 and automatic { i had a 91 thunderbird sport given to me free just tow it off and it ran , and an 87 vic } and put a carb on it and you got a cheap dependable driveline . personally mine , both of them the 53 in my avatar and the 52 customline still got the flatty v8's in them .......... oh and another thing to look for , more complicated a swap but .... i have a 95 tbird with the 4.6 v8 and i have picked up three now , other 4.6 v8's and a 4 valve 4.6 , all sold but the most recent freebie 4.6 two valve with a spun rod , for less than 500 bucks for them in outlay for the two 2 valves and the 4 valve combined , and i paid 200 bucks for the bird running and driveable with a couple of glitches that were esily fixed ............ so happy hunting !!! the deals are out there !!!!!!!!!!
Old Aug 19, 2010 | 04:19 AM
BlueOvalRage's Avatar
BlueOvalRage
I'm not exactly sure from your description how you measured it. The proper way to measure a driveline is to measure the distance between the centers of the u-joint caps with the slip yoke pulled about 1" out of the transmission. Sometimes this requires a minor bit of guesstimation. With that said, I've never seen any reference listing various driveline lengths. I personally just find one that is too long but has the right yokes and have the local driveline guy shorten it to the length I need, but not everyone has that service available.
Old Aug 19, 2010 | 01:10 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
I have gone both ways. Had one made balanced and painted for just under $300 and another time I went to a junk yard that had a semi full of drive shafts in racks. That one was $25 and a couple of hours measuring and sorting. Drive shafts connect at both ends with u-joints, so it does not much matter what the donor vehicle is as long as the u-joint part is compatible with your transmission yoke and axle side u-joint. If you are running 400 hp you will want to look for one 4-5 inches in diameter. There is a great place out there in CA, I think it is called Inline Empire Driveline. But they are not cheap.
Driveline Parts - Driveshaft, Yokes, Driveshaft Yoke, Universal Joint
Look at their site and click Education Zone for drive shaft basic and advanced rules of thumb.
gingerbreadmaniac
Oct 28, 2012 02:36 PM
axlballs
Mar 6, 2011 04:26 PM
rsdjcarter
Jun 3, 2009 05:52 AM
oem78
May 4, 2005 09:23 AM
GeneStoner
2004 - 2008 F150
Jan 12, 2005 07:57 PM
