84 Ford F250
Old Aug 18, 2010 | 11:00 PM
Funcrazy1's Avatar
Funcrazy1
84 Ford F250
UPDATE
update! I fixed and replaced the holly carb with a edelbrock 4 barrel but I don't know how to connect the kickdown and the acceleration cable to it! I have a picture click it make it bigger if need to!
Anything will help! I want it running so I can see how it drives!
Hey guys I'm having some troubles with my 84 ford f250. Today I turned it on 3 times with no problem since I have charged the battery but right after I turned it off. It won't turn at all not even a sound when I turn the key to turn it on. Nothing works at all lights,turn singles, and anything else. So I went under the truck and I noticed there is a ground wire just dangling there that was not there before. I can not seem were this ground came from before. Any help I can post pictures up if need to be.
Old Aug 19, 2010 | 12:18 AM
Barkin 40s's Avatar
Barkin 40s
does the wire have a hole on the end of it like theres sposed to be a bolt through it? if not look on the side and top of the block or anywhere on the block the wire can reach to and see if u find the end of it still on the block
Old Aug 19, 2010 | 12:39 AM
Funcrazy1's Avatar
Funcrazy1
It has a hole on both ends tomorrow I will take a pic of what I'm talking about !
Old Sep 3, 2010 | 10:08 PM
Funcrazy1's Avatar
Funcrazy1
Old Sep 3, 2010 | 10:15 PM
Franklin2's Avatar
Franklin2
You need a adapter like this.
Edelbrock.com - Carburetors & Accessories - Throttle Linkage
Old Sep 3, 2010 | 10:16 PM
Funcrazy1's Avatar
Funcrazy1
alright what about the kickdown? also my throttle cable came off a round bulb thing I can take a pic of the holly carb and show where it was connect.
Old Sep 3, 2010 | 10:18 PM
Franklin2's Avatar
Franklin2
Read the link I gave you. It tells you all about how it works with a Ford auto tranny.
Old Sep 3, 2010 | 10:27 PM
Funcrazy1's Avatar
Funcrazy1
alright I did thanks! hopefully this works! Cause I already have a spacer for the carb ! The holly was shot! It would not start up at all but when I put this rebuilt carb in it starts up every time!
BIKERDEANO
New Member Introductions
Apr 14, 2017 09:19 AM
octaneforce
Dec 24, 2015 12:47 AM
octaneforce
Aug 19, 2015 07:54 AM
2SONS
Mar 25, 2012 11:59 AM
adamsre
Jun 4, 2009 06:50 AM
