Extra Time to Install ARP Studs
Old Aug 18, 2010 | 08:13 PM
ocboat's Avatar
ocboat
Hi all. I'm having head gaskets, oil cooler and egr cooler replaced on my 2004 Excursion PSD at a local dealership all covered by the Ford Diesel Care warranty. Service writer said that they will install ARP head studs if I supply them but he said that they are much more difficult to install and wants to charge me for two hours of labor. Do they really take two more hours to install and torque than the OEM bolts? By the way, I also had the turbo replaced under the warranty about a year ago. The best $1,800.00 I ever spent. Thanks.
Old Aug 18, 2010 | 08:25 PM
ocboat's Avatar
ocboat
Whoops. Meant to post in the 6.0 forum. Mods, please delete.
Old Aug 21, 2010 | 01:17 PM
Forest's Avatar
Forest
ocboat--This is sort of an Excursion question. They may have to lift the body to do this work.
PAY THE 2 HOURS. It is worth it.
Old Aug 21, 2010 | 11:44 PM
X-Hibition's Avatar
X-Hibition
Yes they have to remove the body to pop the heads, that is part of the job. You get that regardless of head bolts or head studs.
Does it take extra time to install studs rather than bolts, well sure. With the bolt you drop it in and torque it. With the studs you have to drop it in, tighten the stud, then add the flat washer and nut, then torque the nut.
But two hours extra? Ya gotta be kiddin!!
Old Aug 22, 2010 | 10:53 AM
ocboat's Avatar
ocboat
I thought that two hours sounded a little extreme but some of the guys on the 6.0l board said that is normal. I negotiated with the dealership for one hour of time and dropped the studs off with them last week.
Old Aug 22, 2010 | 10:57 AM
Snowseeker's Avatar
Snowseeker
Good deal! Well worth the extra $95.00ish to have arp's in there!
Old Aug 22, 2010 | 11:08 AM
jh818's Avatar
jh818
While they're at it, you can have them replace the body mount bushings and put use the polyurethane type if they need to pop the body off the frame.
Old Aug 22, 2010 | 12:03 PM
ocboat's Avatar
ocboat
I'll look into that. Thanks.
HeavyTow
Aug 12, 2022 08:10 AM
DAmbrosini5481
May 3, 2017 02:00 PM
Jlrossini
Mar 20, 2014 09:40 AM
dawiz
Apr 9, 2011 05:40 PM
JDH70518
Mar 23, 2011 02:13 PM
