Quick battery question?
Old Aug 18, 2010 | 06:03 PM
Dyllan78's Avatar
Dyllan78
I left my cargo light on for a couple days and it drained my battery. Do i need new batteries now? Is it going to continue dying on me?
Old Aug 18, 2010 | 07:08 PM
cheezit's Avatar
cheezit
have you charged them and then tested them?
Old Aug 18, 2010 | 07:25 PM
DSMMH's Avatar
DSMMH
Charge them and take the truck to Autozone or Advance Auto and have them do a load test on them or if, you have a load tester, do it yourself.
DSMMH
Old Aug 18, 2010 | 09:40 PM
rocky1074's Avatar
rocky1074
Make sure they are disconnect so you can test them separately.
Old Aug 19, 2010 | 07:44 AM
Dyllan78's Avatar
Dyllan78
Going to go test them at advance auto today, let you know what happens.
Old Aug 19, 2010 | 07:45 AM
Dyllan78's Avatar
Dyllan78
All i did when it happened was put the jumpers on there and leave, had to do it twice before it finally started starting on its own.
Old Aug 19, 2010 | 08:10 AM
Cowboy65's Avatar
Cowboy65
I would recommend using a charger to fully restore the batteries then load test them. Just starting the truck with jumper cables and then letting the alternator charge them will not fully restore the potential of the battery.
Old Aug 19, 2010 | 02:31 PM
Dyllan78's Avatar
Dyllan78
I have a charger here at the house, how long should i charge both batteries for? Do i have to disconnect them or leave them like they are and just attach the charger as is?
Old Aug 19, 2010 | 02:32 PM
Dyllan78's Avatar
Dyllan78
Charger that i have has a little swich on it. It gives the option of 6volts or 12volts, which one should it be on.
Old Aug 19, 2010 | 02:44 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
12v...... and make sure you have enough fluid in the cells.... I would remove those caps and depending on the charger you have, charge at anywhere from 2-10 amp setting. If 2 amp is available, for about 8-12 hours. If only 10 amp is available, 2-4 hours at a time.
