FICM Voltage
Old Aug 18, 2010 | 05:55 PM
350camaro's Avatar
350camaro
FICM Voltage
I just got my new Auto Enginuity cable today. The check engine light is not on, and there are no FICM codes. Tht AE Live Data Meter says that my FICM voltage is 47.5V, is that too low? The check engine light is not on, and there are no FICM codes.
Old Aug 18, 2010 | 05:56 PM
Young Gun's Avatar
Young Gun
Good question. I was always told anything under 48V was a problem but does .5V really mean that much?
Old Aug 18, 2010 | 06:25 PM
npccpartsman's Avatar
npccpartsman
IIRC it's less than that (45 or 46 I think). IF your FICM voltage drops severly on cranking then you have problems, otherwise it's fine.
Old Aug 18, 2010 | 07:05 PM
cheezit's Avatar
cheezit
45v koer is min spec
Old Aug 18, 2010 | 07:39 PM
350camaro's Avatar
350camaro
I took the truck for a ride, most of the time the voltage was at 47.5V but several times I saw it drop to 46.5V. Should I take the FICM apart to check for the bad solder connection, when I have some time?
Old Aug 18, 2010 | 07:43 PM
350camaro's Avatar
350camaro
What does koer mean?
Old Aug 18, 2010 | 07:44 PM
cheezit's Avatar
cheezit
key on engine running
Old Aug 18, 2010 | 07:50 PM
350camaro's Avatar
350camaro
Thanks for the responses. One of these days when I have time I will check the circuit board solder connections.
