1991 F53 Chassis
Old Aug 18, 2010 | 05:39 PM
Mike "O"'s Avatar
Mike "O"
1991 F53 Chassis
Have a 91 F53 chassis with a 460 fuel injected engine. The engine became hard to start and once on the road could not exceed 50 MPH. Problem with the speed is worse. RV won't go over 25 MPH. Changed the plugs, wires, cap, rotor, air filter and fuel filter. No change. Thought the catalytic converter was clogged so it was cut off and engine ran with it off with no change. Had the EGR valve checked by a mechanic who said it was ok and would not cause this problem. I sprayed out the throttle body and idle air bypass and problem remains. Checked the fuel pump and its putting out around 40 PSI when idling. Once engine is started it idles fine. But when you look to give it gas to accelerate it bogs down and sputters. Check engine light goes on and off from time to time. I was told to change the distributor itself that the electronics in that could be bad. Was also told to change the throttle positioning sensor. Any help or advice would be appreciated.
Old Aug 18, 2010 | 06:31 PM
White 97 xlt's Avatar
White 97 xlt
You said the check engine goes on and off,, well what codes are you getting..
You have checked the codes haven't you?
You can throw parts at it all day, and you might hit the right one sooner or later.. or you might not...
Old Aug 18, 2010 | 09:06 PM
Mike "O"'s Avatar
Mike "O"
Unfortunately I don't have an OBD1 right now. Do plan on borrowing one in the near future. Was kind of hoping someone had a similar problem. I'm going to wait til I get the scanner before I go sinking anymore time and money in it.
Old Aug 18, 2010 | 09:26 PM
mechanic58's Avatar
mechanic58
Hmmm, I have a '94 F150 with a 4.9 in it that has the exact same symptoms.
Old Aug 18, 2010 | 10:26 PM
White 97 xlt
Well a code reader is nice,, although a luxury...
Go here to read up on how to do it VERY simple... Ford Fuel Injection How To Run a Self-Test
Old Aug 19, 2010 | 11:35 AM
Mike "O"'s Avatar
Mike "O"
Thanks White 97. If I can't get the OBD1 I'll do it that way. Now I know what the plugs look like, just have to find them on my RV.
Old Aug 19, 2010 | 02:07 PM
mjp_t98's Avatar
mjp_t98
F-53 chassis means Class A, so look just under the doghouse, driver's side. There is a dummy socket for it to fit into that is often on a vertical surface just beside the MAP sensor. It may have fallen out of the socket and be dangling by the wires close by.
What GVW is your F-53. By 94, the 15,200# chassis had no converters; I'm surprised you had one.
As you can measure fuel pressure, do it while you accelerate and see if the pressure keeps up. Apparently pumps can easily fail on these (or filters clog). The Pressure should be 39psi above the pressure in the intake manifold. Most gauges measure relative to atmosphere. So 40 at idle may be too high. It should be maybe 10 psi higher under load than at idle relative to atmospheric.
Old Sep 8, 2010 | 02:42 PM
Mike "O"'s Avatar
Mike "O"
Finally got around to getting the codes on the RV. Codes 55, 56 and 65 flashed up. 55 is key power input to processor open circuit. No idea what that means. 56 is mass air flow circuit above maximum volts of 4.5. Also TOT sensor output is greater than self test Max value or 4.8 volts. Problem here is I don't think there is a MAF sensor on the RV. I checked along the snorkel where I usually see them and nothing. I have no idea what a TOT sensor is. Last code 65 has to do with cycling the overdrive off switch during testing. If someone can shed some light on that TOT sensor, I'd appreciate it. Thanks for the help so far White 97 and MJP
Old Sep 8, 2010 | 02:50 PM
kennethrasnake's Avatar
kennethrasnake
My 87 f-150 done this and it was the Mass Air Flow sensor...And it was about 10* off time.
Old Sep 8, 2010 | 03:12 PM
Mike "O"'s Avatar
Mike "O"
Mass Air Flow sensor is along the intake snorkel between the throttle body and air cleaner, correct? I checked and there is nothing there. I have a class A 34 foot coachmen RV. I don't know if they did something different or it dosen't have one.
Old Sep 8, 2010 | 03:19 PM
kennethrasnake
MAF is on the side of the throttle body(Driver side) in my truck.
Old Sep 8, 2010 | 08:24 PM
Mike "O"'s Avatar
Mike "O"
I'll check again tommorow. I think my throttle position sensor is on the driver's side of my throttle body. I checked on that alldatapro.com and they didn't even list a MAF for my year and engine. All I know this is pissing me off and my tailgating season is starting this Monday night and it don't look like the Rv is making the show..
Old Sep 8, 2010 | 08:46 PM
subford's Avatar
subford
You do not have a MAF sensor on your unit, you have a MAP sensor.
Make sure the vacuum line is plugged into the MAP sensor as they like to fall out and it is hard to see on your unit.
The TOT is the transmission temp sensor in the E4OD transmission, it is just saying the transmission was cold, its OK and not your problem.
55 = For your unit Ford does not list a 55, better recheck or something is wrong with the Computer.
56 = We will say you had a cold transmission and call it OK.
65 = Says you did not push the button on the end of the shift lever when you should have.
Old Sep 9, 2010 | 08:03 AM
Mike "O"'s Avatar
Mike "O"
Thanks subford. I'll check for the MAP sensor and vacuum line. Hope thats it.
Old Sep 9, 2010 | 11:13 AM
Mike "O"'s Avatar
Mike "O"
Hey guys, ran another diagnostic check and I appeared to get 3 digit codes after it gave me my 2 digit. It gave me 56, 55, and 65 first, I left the key in the on position and it flashed 112 and 212. If someone could shed some light, would be appreciated. Going out now to check for the map sensor and vacuum line.
